| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
Hi, group. I'm having a blonde moment, I'm looking to build a full range speaker with 2 15" speakers, similar to GSM-3250, or Peavey PV 215 Dual 15" 2-Way Speaker Cabinet. If put power amp for 15" woofer separately I with get more out put correct.
amp 1 amp 2 amp 3 15" @ 200w + 15" @ 200w + 100w tweeter = 500w?
#2 |
Commercially speaking they would be additive, technically speaking not exactly. Certainly you can claim 400W power to the woofers and 100W to the tweeter.
There's no particular reason IMO to use a separate amplifier for each woofer - I'd probably go with a 400 - 500W amp designed to drive the parallel impedance of your woofers, and I would probably choose 8 ohm woofers for this reason. You will need to make sure that the tweeter can keep up with the woofers and with a 100W amplifier should be at least 6dB more efficient (assuming 400W woofer amp) than the combined efficiency of your woofers. Make sure that it can handle the required power around the cross-over point as it is likely to be working pretty hard at the low end of its response range. Others will probably have a lot more insightful comments to add, mine are simplistic and probably just part of the story..
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#3 |
Thank you!
I thought this was the case, FYI the rms value for the tweeter in question 175w, 250 watt max, but I don't see a need to drive that much high frequency output. |
#4 |
The wattage of your amp/speakers are of less concern than the sensitivity of the speakers...
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
#5 |
A question about speakers:
I would like to know if I can use a 60W house speaker with my car radio in my home. No external amplifier. Just the one speaker. I presently am running a car speaker rated at 91dB, but it seems to run rather hot. Thanks. |
| Am I loosing power somewhere? | scutterflux | Power Supplies | 23 | 26th April 2012 03:16 AM |
| My Solderpump loosing suction? | jeanious2011 | Equipment & Tools | 17 | 21st June 2011 01:56 AM |
| KT66 loosing its getter | ixe13 | Tubes / Valves | 2 | 27th February 2008 01:33 AM |
| Loosing my BASS somewhere! | NickUK | Car Audio | 3 | 3rd January 2007 01:29 AM |
