PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Adapter to test Shure Countryman headset mic
Old 6th September 2012, 11:39 AM   #11
Burnedfingers is offline Burnedfingers  United States
So, on my drawing just remove the coupling cap. Take the battery directly to pin 3 on the TA4 male connector. Remove the wire on 3 from the TA4 male to the XLR pin 3. Jumper pin 3 to pin 1 on the XLR connector.
Old 6th September 2012, 01:40 PM   #12
imix500 is offline imix500  United States
imix500's Avatar
Almost there,
You still need a decoupling cap to block dc, the difference is you just need one and it's tied to the same conductor as power+. I don't have access to my laptop to whip up a drawing so I'll try to discribe it-
TA4-
Pin 1 battery - to pins 1&3 on xlr
Pin 3 battery + to coupling cap to pin 2 on xlr
Pin 2 is NC since it only feeds a current source in the wireless pack.
Old 6th September 2012, 10:22 PM   #13
Do I have it?
Old 7th September 2012, 02:25 AM   #14
imix500's Avatar
Looks good.
Old 7th September 2012, 10:52 AM   #15
Thanks for the help. I guess it would serve me well to have a cup or two of coffee to wake myself up before I post. Do you have any ideas as far as possibly using this to check other headsets? I have looked for the Avlex pin out and cannot find anything on it.
Old 7th September 2012, 11:17 AM   #16
Ok, can I modify this further to allow it to be plugged into a mixer with phantom power without any damage?
I added a blocking cap on pin 3 XLR mixer to pin 1 shield.
Old 26th September 2012, 03:49 PM   #17
imix500's Avatar
Sorry, I stopped getting notifications for some reason. You probably already have it figured out, but here are my thoughts.
I haven't worked with the Avlex mics but they should be similar. Most manufacturers are moving to a single shielded cable, but i think a few are still 2 or 3 conductor with shield.
Actually, just looking at the pictures they use a similar cable as the countryman, so the setup should work.
The test rig should work as drawn, but the blocking cap between xlr pin 1 and 3 isn't really needed. Both pins should be at ground audio ground and battery ground.
Adapter to test Shure Countryman headset micHide this!Advertise here!
Advice For Splicing A mic Wire in headset outlaw939 Everything Else 0 10th August 2011 11:51 PM
B&K tube test adapter TC-1 TommyR Equipment & Tools 0 8th November 2010 06:14 PM
Shure M95HE and Shure M97HE stylus interchange ashok Analogue Source 0 28th October 2009 06:34 AM
WTB B&K 4117 mic or UA 0205 adapter AVWERK Swap Meet 0 4th December 2005 09:14 PM
Shure Beta 58 A mic good for reporters? kris.k Everything Else 2 22nd October 2005 06:58 AM
Copyright ©1999-2017 diyAudio
