| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
Hey guys, I've read a lot of posts before posting this for days on end. Hope I can get some feedback. Came into some DJ equipment at a price my partner and I couldn't turn down. Anyway I've been reading and downloading manuals (for the amps) trying to understand all the capabilities. (slowly getting there) I'll list what I'm using, how I'm using it, and I'd appreciate any and all feedback, on what I may need to subtract or add in order to gain optimum performance out of this equipment. I Dj with Virtual Dj Pro Version, using an HP G7-1310us, with a Numark Mixtrack Pro Controller, I run that into -
American Audio Q-D6 SRS3 Mixer along with (2) Americn Audio CDI-300 CD/MP3 Players the mixer is run into: NADY GEQ 215 2ch 15 band EQ which is run into: Behringer Super-X Pro 2310 Crossover then come the amps: Crown XTI 4000 - runs the mains QSC RMX 1450 - for bass/subs speakers: 2 Peavey SP2 2 JBL JRX125 2 Peavey PV15m I also have a pair of older Gemini Passive subs (15") that I don't always bring out because really they aren't needed due to size of the venue. We also came into an SWR Goliath III bass speaker (the one with the 4 10's and horn) I told my partner that I didn't think the Goliath was the appropriate type of bass speaker for what we do, I'd rather sell that and get a Peavey 18" sub or two and use that instead. We've tried out the Goliath on some smaller venues where we didn't need much in the way of loudness due to room size. But it didn't give me what I'd like to get sound wise. I am bridging the output of the bass amp. Honestly not sure if maybe I should switch and use the QSC for the mains and the crowns for bass. I've got the system sounding decent, but I'm thinking it can be better. Also I'm still trying to figure out the best way to set up the Crown amp as far as the presets go for optimum sound for the mains. One other thing I've tried is bi-amping both sets of Peavey speakers on another smaller function, the problem there is you can daisy chain in full range mode, but bi-amp, that option isn't there. Thank You in advance! ![]() ![]() ![]()
#2 |
Sell all the speakers/bass guitar stuff and invest in some good light tops and buy/build a set of better subs.
That is a hodgepodge collection of speakers that would only be good for a metal band. What type of music and how many people do you plan on DJ'ing for? |
#3 |
If you are going for sound quality, dump the mixtrack pro and american audio mixer. **** in = **** out.
Get an Native instruments S4 or even better, a Xone 4D. |
#4 | |
As far,as good light tops, what would be a good choice, I wish I could say 'money ain't a thing' but such is not the case, trying to make the best of what I have. Last edited by icmeinu; 27th August 2012 at 04:22 PM. |
#5 | |
![]() The upgrade is coming and will probably be the S4. As far as the amps and other stuff, am I heading in the right direction ( so to speak ) Thanks! |
#6 |
Proud Union Member
Of the three pairs of speakers you have, I would use the SP2 and do something else with the other two pairs. The JRX even with the dual 15 are not going to take more abuse than the peavey. The PV15m are stage monitors. If you plan on using them for "texas headphones" fine, but they are a compromising choice for mains.
If you need more tops, get an identicle pair. Mixing different brands or models does not usually work well. Splay them out so each pair covers the room evenly. You have plenty of power for just one or two pairs of tops and a pair of subs. Which amp on what doesn't matter too much, but I would run the sub amp in stereo. Honestly, with one pair of 8 ohm subs around the size of the Geminis it probably doesn't matter. If you really needed the capability to load down the amp you would be looking at multiple 20A circuits to power the rig. As far as subs- If the Gemeni subs work there's nothing wrong with using them. Sure there are better subs, but if they provide enough output for the gigs you do I would keep using them until your venues grow and they become insufficient. If two are too much for the gig just bring one and turn down the other sub amp channel. The SWR as you have found its ment for bass guitar not so much PA reinforcement. Last edited by imix500; 27th August 2012 at 07:15 PM. Reason: Autocorrect |
#7 |
First off you need to decide how big/loud/amount of bass you need want. Next is to decide the allowed size and weight you want to carry. Factor in appearance also if you do weddings or other formal events. Psrt of the problem is you have a mismatch of speakers. They dont acousticly blend well together and dont look good either. Do the jrx/sp2's have enough output for your needs not taking bass output into consideration. If so, decide which ones you like the sound of and buy a 2nd pair of those and sell the others. Bring 2 for small gigs and 4 when needed. For subs i would consider 4 of the tham15's found on this site. The crown amp is great but you will what to upgrade the qsc to sometjing bigger or simply get a 2nd one. Use each 1450 to drive 2 subs. As for the other gear, realistly you will want to replace it all but get the speakers sorted first.
#8 | |
As for bass and the sound I'd like, the Gemini's are ok, was just thinking about a punchier (if there is such a word) deeper sound, all that may just be a matter of equalization or lack thereof. They usually come out for the big parties. A normal set up (small) would be the sp2's on the floor and the Gemini's on the tripod pic attached (hopefully) And I understand what you say about the asthetics of how the equipment appears once setup. Thanks |
#9 |
Proud Union Member
The biggest issue with running the system the way shown in the picture is time allignment between the two pairs of speakers. You get some crazy acoustical interference because the sound from the two pairs is arriving at the audience at two different times.
#10 |
I hear what you are saying, but don't completely understand, I do know that once we were hooked up it took a minute to the sound situated. The room itself was small, the venue was setup for 60 people. But I'd like to know more about what you are referring to
| DIY DJ setup? | oscurochu | PA Systems | 7 | 4th January 2012 02:37 PM |
| DJ Full Deck Setup Power Consumption | upx6 | Equipment & Tools | 0 | 6th January 2011 08:38 AM |
| Input on 5.1 diy setup, budget friendly *n00b* | Blazin_Jason | Multi-Way | 18 | 20th January 2009 09:32 PM |
| would like some input on a setup | ChemMan | Multi-Way | 4 | 9th December 2003 05:14 PM |
| DJ Mixer | Samuel Jayaraj | Solid State | 4 | 2nd February 2002 09:07 PM |
