PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Dj Setup - Need input - Thanks!!!!!
Old 27th August 2012, 09:29 PM   #11
imix500 is offline imix500  United States
imix500's Avatar
Hi icmeinu,
with many people contributing on a thread it can be difficult to know who is responding to who, but I think you were replying to me. If not- please ignore.
The pair of speakers on the floor are in front of the pair on tripods by a couple feet by the looks. Sound comes out of the speakers at the same time, but because the speakers on the floor are closer to the audience the sound from them arrives just before the tripod speakers. This causes phase cancelation between the two pairs at different frequencies depending on how far in front of the tripod speakers the floor speakers are.
You could use delay processing to align them, but honestly those speakers on the floor are really just hitting peoples knees. You would be much better off putting another pair on tripods next to the existing pair in the pic pointing towards the dance floor if you need more coverage there.
Old 27th August 2012, 10:01 PM   #12
icmeinu is offline icmeinu  United States
icmeinu's Avatar
Actually after thinking about what you said about the speaker placement, I believe I do understand, but what would you have done differently?
Old 27th August 2012, 10:20 PM   #13
imix500's Avatar
If it were me, I would have used the pair on tripods just as they are and added another pair of the same right next to them. So you have the outer left and right pointed straight ahead or whatever gives you the best coverage for the room, and the inner pair pointed at the dance floor.
Old 27th August 2012, 11:35 PM   #14
icmeinu's Avatar
Ok, that would have work. so basically having the speakers on the tripod slightly behind the sp2's creates the variance in sound travel u spoke of in previous post?
Old 28th August 2012, 01:10 AM   #15
SonicXtasy is offline SonicXtasy  United States
Are the Gemini subwoofers the speakers that are on the poles in the picture? If so....get rid of those piece's of crap!!! Your Peavey's or JBL's produce as much bass as those Gemini's. Also you want your main speakers up on the poles to get the sound out to the crowds and put the subwoofers on the floor because you gain additional bass by coupling them to the floor. Actually subwoofers work best when put together and if you can put them in a corner of the room (solid wall) they will be even louder and fill the room nicely.
This vid was shot to show my LED bars but this venue holds 400 people. You can see my main speakers on the far edges (the inner speakers were the venues and not used). You can't see it but I have my yorkville 2 X 18" bass bin in the far right corner and it filled the room nicely.
<iframe width="420" height="315" src="SonicXtasy's LED light bars up lighting curtains on stage. - YouTube" frameborder="0" allowfullscreen></iframe>
A good subwoofer will make those PVs or JBL's seem larger than life.
Old 28th August 2012, 01:36 AM   #16
imix500's Avatar
Yes, for time alignment it's all about distance. Sometimes it is correctable with processing like I mentioned. You could delay the speakers on the ground back so they line up with the tripod speakers. With a straightforward system, a few relatively free practices kept in mind can take care of it without the need for another processor.
Adding to that, it's a good idea to get the speakers off the ground and put the subs there instead (or put both subs together in the center, playing with sub placement can be fun if you have the time)
Old 28th August 2012, 01:40 AM   #17
imix500's Avatar
SonicXtasy, I'm pretty sure the speakers on tripods are some brand of molded plastic 2-ways. (I think I see the shape of a horn and porting on either side)
Old 28th August 2012, 01:55 AM   #18
I agree that that is what they look like but in his first post he said he had Gemini 15 inch subwoofers. Later in the post with the picture he said he put the Gemini's on the poles and the PVs on the ground which made me think that those were the Gemini subwoofers that he was talking about.
Old 28th August 2012, 02:54 AM   #19
imix500's Avatar
Hmm, you are correct. I read right over that. Maybe icmeinu could clarify.
Dj Setup - Need input - Thanks!!!!!Hide this!Advertise here!
DIY DJ setup? oscurochu PA Systems 7 4th January 2012 02:37 PM
DJ Full Deck Setup Power Consumption upx6 Equipment & Tools 0 6th January 2011 08:38 AM
Input on 5.1 diy setup, budget friendly *n00b* Blazin_Jason Multi-Way 18 20th January 2009 09:32 PM
would like some input on a setup ChemMan Multi-Way 4 9th December 2003 05:14 PM
DJ Mixer Samuel Jayaraj Solid State 4 2nd February 2002 09:07 PM
