PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
PA speaker resistor blew... quick question.
Old 22nd July 2012, 02:11 PM   #1
schpadoinkle666 is offline schpadoinkle666
Default PA speaker resistor blew... quick question.
The resistors on my speaker cabinets blew out, I ordered new ones. would it mess anything up to change out this resistor with a 5w 8ohm one instead of the 5w 4 ohm one?
Im using a soundtech 500w 8ohm PA head and 2 15"+tweeter cabinets...
Old 22nd July 2012, 03:28 PM   #2
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Yes, going from 4 Ohms to 8 Ohms will mess things up!
(Cross-over frequency wise or maybe volume of one of the drivers)
But, going from 5 Watts to 10 Watts would be good.
Kevin
Old 22nd July 2012, 03:35 PM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
More importantly, you have to ask why the resistor blew in the first place. I suspect you've been overdriving the amp, causing clipping. Replacing with a higher wattage may just cause the drivers to blow next time.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 22nd July 2012, 07:19 PM   #4
bear is offline bear
expert in tautology
bear's Avatar
if that is in series with the drivers, you might consider putting a lightbulb of appropriate size in series with the entire HF xover or right before the tweeters... the resistance raises when excess current flows and lights the bulb... it doubles as a fuse... an automotive tail light bulb is commonly used for this.
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 23rd July 2012, 04:16 PM   #5
CCU is offline CCU  Denmark
Send a message via MSN to CCU
Or a cheaper alternative would be a halogen bulb
They can be had for next to nothing and have similar performance
Old 23rd July 2012, 05:44 PM   #6
expert in tautology
bear's Avatar
They have brittle filaments, I would not use in a situation where I needed to rely upon the speaker. Auto bulbs have rugged filaments designed to work under constant vibration... Plus you can solder to them.
_-_-bear
_-_-bear
Old 23rd July 2012, 10:55 PM   #7
My bad. I've haven't tried it myself. but seen it used several times, newer thought about the vibration part
Old 24th July 2012, 03:24 AM   #8
expert in tautology
bear's Avatar
hey, no bad. good thought! I think they make halogen automotive bulbs!!
_-_-bear
Old 24th July 2012, 04:00 AM   #9
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
That would be a great idea to use a light-bulb for protection (I have heard of the concept).......To take the idea to a higher level, one could incorporate an automotive bayonet base into the front baffle, giving easy access & function as a visual aid.
__________________________________________________ ___Rick...........
Old 24th July 2012, 04:16 AM   #10
googlyone is offline googlyone  Australia
Rick
The bulbs work a treat. They do not really light up though - unless i suppose you were trying really really hard to blow things up. Though at that point I suspect that a dimly glowing bulb would be something less of an indication than the noise and smoke emanating from the speaker!
Used the bulb trick in some cabinets for my brother. You want to characterise the particular bulbs you use. I found two 12volt 12watt bulbs to be just right. You could probably drop these in place Of a 4 ohm resistor as their resistance was from memory an ohm or two.
PA speaker resistor blew... quick question.Hide this!Advertise here!
Power Amplifier blew and took a speaker with it Someone7272 Solid State 89 2nd June 2010 05:33 PM
hafler dh200 blew speaker? hostarn Solid State 18 26th May 2009 01:01 AM
Quick Speaker Question JPeitzman Multi-Way 0 16th January 2009 06:20 AM
PA speaker cab cinfig question godfearingjerk Instruments and Amps 4 12th November 2005 09:05 PM
Help with Gainamp. Test resistor blew. downhere Chip Amps 13 25th November 2003 01:55 PM
