PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
25hz horn for PD2150/2450
Old 19th August 2012, 01:55 AM   #11
GM is offline GM  United States
GM's Avatar
Greets!
Your links don't work.
Well, default compression horn design using published specs yields a 19-190 Hz hyperbolic FLH, so you're covered at both ends. Load the attached file into HornResp to get all the design details.
GM
File Type: txt pd2150_f.txt (419 Bytes, 61 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 19th August 2012, 09:08 AM   #12
epa is offline epa  Netherlands
25 hz seems unrealistic to me.
may i ask what kind of music?
is it for pa?
will you be using 1,2 or 4 per side?
i just put in hr for fun.
1 horn 25hz 2 pi space(outside ground floor) you need a horn 515 mtrs long,system volume 8650ltrs(when bild ~10m3).
if you change it to 35 hz you would need less then half the volume.
grtz erik
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 19th August 2012, 09:35 AM   #13
soundguf is offline soundguf
Plywood in moduls
Old 19th August 2012, 10:08 AM   #14
Thanks GM i'll try to take it from there.
Old 19th August 2012, 02:43 PM   #15
GM's Avatar
you're welcome!
Hmm, I posted on the other thread, so assumed a 1pi space loading. For an outdoor 2pi loading it needs to be larger, but due to HR's mouth size limitation I had to increase the cutoff to 21.7 Hz, which is still low enough to achieve your stated performance requirement.
GM
File Type: txt pd2150_2.txt (419 Bytes, 18 views)
25hz horn for PD2150/2450Hide this!Advertise here!
WTB:JBL 2450 neskor Swap Meet 0 19th February 2012 07:31 AM
Amp and eq for Precision devices PD2150... Hypex? JiiMKV Class D 4 22nd February 2011 06:24 PM
Help! How to measure 2450 volts with 1000 volt max meter. ichiban Parts 8 6th June 2009 03:10 AM
PD2150 impedance, are 4ohm and 8ohm re-cones interchangeable? Puggie Subwoofers 2 28th March 2006 03:24 PM
How to choose 15" drivers for QSC 2450 amp? lunchmoney Multi-Way 9 5th May 2005 06:40 PM
