how to Connect Studiomaster mixer to active speakers? - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 3rd April 2012, 03:17 PM   #1
Default how to Connect Studiomaster mixer to active speakers?
Hi I have a classic Studiomaster 8 into 4 mixing desk and would like to know which inputs i need to connect 2 active speakers to in the back of the desk, i dont want to fry it!........
Ive included a picture of the back for you to look at and any help would be appreciated thankyou Richie
Connecting powered speakers to studiomaster desk | Pro Audio Questions that is the link for the picture of the back of the desk thanks.
Old 4th April 2012, 12:02 AM   #2
Ferrit37's Avatar
Hey Richie,
you don't say make/model of the active speakers and if they have XLR balanced or 1/4" input, HI z or LO z impedance. But typically the outputs from the console should be line level, balanced (pin2+) 0dB if you are unbalanced 1/4" you would need an adapter with tip to pin2 and ring strapped to pin 1 and 3 on the xlr.
If your active speakers are -10dB input you will need a resistive pad/attenuator on the output of the console (google inline pads)
I used to have several 24/4/2 studiomaster(RSD) consoles a long time ago back in the UK.
hope this helps
Warmest regards,
Ferrit37
Old 4th April 2012, 08:11 AM   #3
Any you could recommend??, they need to be big enough for an average pub type venue for a solo singer......Ive looked around but im not sure whats good and whats not I know if i spend bucketloads there are a lot of companies i could trust such as Mackie but im not sure!?.....
Old 4th April 2012, 06:21 PM   #4
ATC-XTC is offline ATC-XTC  United Kingdom
The 15" JBL Eon would be ideal for this, you can usually pick them up from ebay for a reasonable price. One thing to watch is that as this is an old (probably over 25 years!!) budget desk the XLR outputs aren't balanced and the hot (signal) connection is on pin 3 if you're connecting it to a active speaker with balanced inputs using the pin 2 hot convention, to achieve optimum results I'd recommend that you make up a cable like this:
Speaker pin 1 connect to screen of cable leave unterminated and insulated at mixer end
Speaker pin 2 connected to pin 3 of mixer output
Speaker pin 3 connected to pin 1 of mixer output
This method used to be called pseudo balanced (maybe still is??) and will reduce hum and correct the phase of the system, just make sure that the screen isn't allowed to come into contact with any of the pins or shell at the mixer end, this is easily accomplished by cutting the screen where you have stripped the cable and pulling the insulation back over the stripped end, there will usually be enough give in the pvc to cover any exposed screen, use some helleman insulation sleeves or tape for a professional job.
HTH
Stu
Old 4th April 2012, 06:53 PM   #5
Ferrit37's Avatar
Hey Richie,
Well I actually work for a sister company to Mackie, the SRM450 is a great value, also the JBL EON series is verey good, these are all pole mounted, so you should look at maybe getting ultimate support stands, or something similar
Warmest regards,
Ferrit37
Old 5th April 2012, 01:10 PM   #6
Ok, so what about connecting a separate power amp to this desk and running two passive speakers from there is this possible??.....and if so how??
Old 6th April 2012, 04:20 AM   #7
Ferrit37's Avatar
Hey Richie,
this is all pretty basic stuff assuming you are using a pro amp
try : PA System Schematic Diagram - for a simple layout
and this: Sound System Interconnection for a "decoder-ring" on interconnects
cheers
Warmest regards,
Ferrit37
Studiomaster Club 2000 dsp mixer kebab69man Chip Amps 5 1st November 2010 06:39 PM
studiomaster focus 808 600w power mixer rjb100 Solid State 0 27th October 2010 08:26 PM
Help to connect powered mixer with amp. Remo Di Solid State 1 9th July 2010 12:31 PM
How to connect speakers in both stereo/mono? revans Multi-Way 8 9th October 2008 09:40 PM
Active cross-over, solid state amps connect directly to tweeter? Drew Eckhardt Multi-Way 14 24th August 2003 06:36 AM
Copyright 1999-2017 diyAudio
