PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Simple high quality audio amp using tip41 & tip42
Old 27th March 2012, 08:45 PM   #1
rrbadrike is offline rrbadrike  India
Default Simple high quality audio amp using tip41 & tip42
I have build this amp.I have attached the schematic & completed photo of amp.You have to just replace transistor MJE3055 with TIP41 & MJE2955 with TIP42 in the schematic.
Old 29th September 2013, 04:48 PM   #2
mangga is offline mangga  Indonesia
thank you
Old 29th September 2013, 04:53 PM   #3
Mooly's Avatar
TIP41 aren't suitable due to the low 40 volt rating. For a 70 volt supply (which is what this amp shows and is what the devices can see under drive) you must use at least TIP41B (marginal at 80 volt) or preferably TIP41C (100 volt)
Old 11th December 2013, 03:16 PM   #4
Vintage Amp Builder is offline Vintage Amp Builder
What is the max output power??
Old 11th December 2013, 04:53 PM   #5
Mooly's Avatar
Its easy to work out.
-/+ 35 volt rails gives an output swing of -/+35 less say 5 volts losses across the transistors and 0.22 ohm resistors.
So -/+30 volts is 21 volts RMS. (calculated by taking Vpeak which is 30, and multiplying by root 2)
Watts is V squared/R so put your own numbers in now. For example its 27 watts into 16 ohm.
Old 15th December 2013, 12:08 AM   #6
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default TIP41 TIP42
470uf 100 volts to be used on supply rails
"It's Better to try and fail than to never know and always wonder"
Old 15th December 2013, 11:10 AM   #7
ATAUDIO is offline ATAUDIO  Austria
Default Credits
It looks like the Rod's ESP original P3 Project - see- High Quality 60 Watt Power Amplifier
or also his guitar amplifier, apart for your (questionable, as others have reported) choice of the outputs.
In such case at least credits should be given to the original author.
However, such amplifier (in its evolution P3A) has proven really good to me for P.A. use, in "emergency" situation.
See - THIS THREAD
@Audio
Simple high quality audio amp using tip41 & tip42Hide this!Advertise here!
Problem with tda2030a+tip41/tip42 120w amp rrbadrike Solid State 6 1st April 2012 10:20 AM
HPA-2 Headphone Amp Kit (High quality & High-end components) kawo Group Buys 20 17th February 2012 04:34 PM
mixer circuits (looking for simple, but very high quality)... dfeweer Analog Line Level 6 21st December 2011 09:58 PM
High Quality headphone amp shark70 Chip Amps 1 16th March 2010 01:38 PM
High Power High Quality Digital Amp aspycaudio Digital Source 0 6th December 2003 09:49 AM
Copyright ©1999-2017 diyAudio
