| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
#11 | |
I know something about deep cycle batteries and would like to chime in here. There are NO deep cycle batteries that can be ran down nearly dead. 10.5 volts is as low as any deep cycle battery that is expected to be used more than once should be discharged, this represents about the half way discharged mark for lead acid batteries and any more (lower) than this WILL DAMAGE YOUR BATTERY! |
#12 |
Now it is down to batteries
There is one chemistry that can be run to dead--it actually likes to be run down to 0V on occasion--NiCad batteries. Lead acid is cheap but don't like to be deep discharged, they are also very heavy and perform poorly in the cold. The best battery to use in the cold, can be discharged to 80% without damage for thousands of cycles, is safe and non-toxic is Lithium-Iron-Phosphate. The code on the side states LiFePO4 so you know you have the right type. The size and weight savings over lead-acid is about 4 times lighter and 4 times smaller which allows more capacity and much longer runtimes. Cheap? No--not yet but the prices have been falling for years and they can be charged from automotive chargers. Make absolutely sure the automotive charger does not have a trickle charge function, the only battery that likes to be charged at 100% constantly is lead-acid. Shut off the trickle charge function on the charger. Most of the LiFePO4 batteries have a battery management board to shut down the battery once it gets down to below 20% charge--make sure you get one that does this so the pack can be used for many, many years without problems. Charge it up once a year when not in use and go. |
#13 |
+1
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| EQ vs Wattage (portable PA) | ekbaird | PA Systems | 4 | 18th January 2012 11:50 AM |
| Portable PA system | renzuken101 | PA Systems | 14 | 4th November 2011 02:50 AM |
| T-amp for guitar busking/portable PA | Racket Scientist | PA Systems | 6 | 14th June 2011 10:18 PM |
| help pls, challenging design - portable PA | tbodin | PA Systems | 2 | 29th January 2008 07:49 AM |
| Portable PA requirement - need input please. | biggerbyfar | Class D | 13 | 14th January 2007 11:40 AM |
