Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 14th February 2012, 12:05 PM   #1
Default Need help with Yamaha EMX860ST - blown monitor amp?
Hi, I recently acquired a Yamaha EMX860ST powered mixer, which has 3 amps inside (1 for monitors, and 2 for mains Left and Right). The mains amps work perfectly, even in bridged mode. The monitor outputs in the back of the amp do not output any sound, although monitor section on the front panel appears to be working. When the level knobs are turned up and a mic is used, the LED meters light up according to the level of input received from the mic. Also, the monitor out on the FRONT of the amp that is meant for you to send to an external monitor amp (does not run through an internal power amp) does work, and the rest of the monitor controls correctly modify that unamplified signal. So it appears only the power amp for the monitor section is not working, and everything else appears to be fully functional, including the EQ's, level meters, reverb effects, etc.
I'm a novice at electronics repair. 20 years ago in a past life I graduated with at EET degree but haven't used electronics repair since working in the IT field. I paid $100 for this amp used site unseen and I can get my money back from the seller. It still has some use as a rehearsal amp so I may keep it. But if I could get the monitor power amp working it would be fully functional for small gigs. However I know if I take it to a repair place it will be relatively expensive to have them fix and I would be better off buying a functional Peavey XR600f or the like.
Any advice on if there are common things on these old EMX powered mixers that might be an easy fix that would account for just the monitor power amp not working? I need to decide if it's even worth opening up or if I should just go get my money back. I can look for visible burnt traces and components, and repair/replace them, but I don't have much experience tracing voltages through circuits. Am I over my head and should punt?
Any help is greatly appreciated.
Old 14th February 2012, 12:35 PM   #2
Enzo is offline Enzo  United States
The vast majority of failed parts look no different from good ones. Flames and soot are very much a minority of failure modes.
I don;t have the schematic with me, so I cannot look it up at the moment, but if you feel like it, open it up and see if there are separate fuses for the three amp circuits. Beyond that, there is not much that won;t require soldering parts on the circuit board and identifying where the failure lies.
Connect a speaker ONLY to the monitor amp outs. Is there any sort of turn-on thump or pop when power is turned on? You say no sound comes out, as in signal, but is there ANY sort of background sound? For example the amp might be working but the signal is not reaching it. It might still then make some little sign-of-life noise.
And I don't have a good close up photo, but if there are any POWER AMP IN jacks on the panel, if there is one for the monitor amp, plug a signal into it and see if it drives the amp to produce output. A dirty cutout contact in such a jack could inte3rrupt the signal path.
And if the power amp assign switch mentions the monitor function on any position, exercise that switch a few times and se if that helps. More times that I would think, someone has brought me a mixer with a "dead" channel that was really just the amp assign switch in the wrong position or dirty.
That's the simple stuff.
Old 14th February 2012, 12:50 PM   #3
Thanks Enzo. I appreciate the quick reply and have enjoyed reading your other troubleshooting on other threads.
There is NO sound coming from the rear monitor jacks, including at power on and power off. I am using the same speaker and speaker wire which work great on both main left jacks and both main right jacks.
There is no selector switch that involves the monitor sections, only the bridge/stereo switch for the mains, and the phantom power switch, which I have toggled and both seem to be working.
Unfortnately on this powered mixer their are only AUX inputs for the mains, not the monitor section.
Here is the manual with crappy pictures:
http://www2.yamaha.co.jp/manual/pdf/...EMX860ST_E.pdf
So probably someone connected a shorted speaker or speaker cable to the monitor outs and fried some components in the monitor power amp section, right? How many hours on the bench do you think a reputable shop would charge to troubleshoot and fix if it is just checking resistors, caps, IC's in just the monitor power amp section? I know it's impossible to know and every case is different. Would you guess a 1-2 hour charge or a 3-4 hour charge?
Old 14th February 2012, 02:03 PM   #4
I just contacted a Yamaha repair shop in Orlando and they charge $75/hr but of course wouldn't guess on the number of hours. But if it takes 2 hours plus parts and tax, I guess it's already not worth it for an older powered mixer like this. I guess I could just keep it as a rehearsal/backup amp. Its kludgy, but I could run 2 mains of the L main channel, and 2 monitors off the R main channel and use the Pan controls attenuate the volumes to the monitors. All speakers would share the same master EQ. Or I would have to bring along another power amp for the front monitor out.
If anyone has anything else I can try to check, or things you've seen go bad in EMX power amp sections before please let me know.
Yamaha M-45 Blown Output Transistors gni Solid State 35 29th July 2008 09:47 PM
B&W 220i tweeter blown,replacement ?? gazzz Multi-Way 3 9th May 2008 12:54 PM
help blown yamaha amp namcir Solid State 18 12th December 2005 03:37 PM
Yamaha NS-1000X tweeters blown...whats the problem? young_pup Multi-Way 10 1st October 2005 07:41 PM
Yamaha P-2200 blown-up xyonyx Solid State 5 13th November 2004 07:54 AM
Page generated in 0.09691 seconds (84.44% PHP - 15.56% MySQL) with 10 queries
