Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 17th February 2012, 07:55 PM   #31
pinkmouse's Avatar
Positive on + should make the cone move out. NL4s are wired with the bass on 1 and the treble on 2, so if a NL2 is plugged in by mistake the tweeter doesn't get driven full range.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 17th February 2012, 08:18 PM   #32
I don't understand what you are saying. Postive on positive? + on +? Huh?
means nothing to me. Bass driver on only one terminal? Treble driver on only one terminal? You lost me.
I understand the NL2/NL4 concerns, but I don't really know how to wire either.
Saw it online somewhere though...
On the NL4 the bass is on TWO terminals, and the treble on 2 others...which of the 4 terminals are paired for one driver, which are paired for the other driver? And then which of each pair is + for cone to move out?
For the 1/4" is the tip or the sleeve positive for the come to move out?
Old 17th February 2012, 09:19 PM   #33
pinkmouse's Avatar
+1 and -1 for the bass. +2 and -2 for the treble. Positive voltage on + move the driver out.
Al
Old 18th February 2012, 12:11 AM   #34
Is the speaker a bi-amped speaker or a full range with an internal passive crossover.
Mike C.
Old 19th February 2012, 10:51 PM   #35
OK I think my confusion woth the NL4 is how the pins are numbered. I can't see mine anymore (mounted and shrinwrap) so I'll buy a plug and use a meter to see which color wire is which. I should have written it down before covering. So if the NL4 are +1/-1/+2/-2 I'd expected just 1/2/3/4.
For the 1/4 inch plugs another thread post said + on the TIP moves cone forward so I'm OK there now.
Old 20th February 2012, 08:21 AM   #36
pinkmouse's Avatar
This might help, wide keyway on the front aligns with pin 1+
Al
Old 20th February 2012, 01:42 PM   #37
1-, 1+, 2-, 2+ would become 1, 2, 3, 4 if you count the way most folks do!
Old 20th February 2012, 02:43 PM   #38
Back to post #1: How abot these:
need binding posts for #4 wire, mount on steel plate cyclecamper Parts 12 20th December 2011 08:20 PM
1/4" Jacks TS/TRS Panel Mount Jack GLS Audio Headfi Fanatic Group Buys 0 14th July 2010 06:16 PM
Need ppi art pcb mount rca jacks ppia600 Parts 1 15th October 2007 03:02 AM
chassis mount RCA jacks biff584 Parts 6 12th February 2005 06:23 AM
DIY silver RCA panel mount jacks tom1356 Everything Else 4 1st August 2003 05:43 PM
Page generated in 0.08503 seconds (74.43% PHP - 25.57% MySQL) with 11 queries
