Tips for Small Venue set up - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 27th December 2011, 05:25 PM   #1
Default Tips for Small Venue set up
Im looking for some live sound advice.
If i was working with a powered mixer of 1600 watts / 800 + 800.
and have (2) 1200 watts peak 4 ohms , (2) 1000 watts peak 8ohms, and (2) other speakers which im not sure of specs wise. How loud can it get? would the mixer actually give me 1600 watts of power? Or should i say enough power to make vocals pop out to a small venue with about 100-150 peeps in it? I also have a power amp with 3000 watts @ 80hms bridge.. what does this mean?
Old 27th December 2011, 07:14 PM   #2
Bone is offline Bone  United Kingdom
You shouldnt need 1600 watts in a small venue of ~200 people. 200 watts should be enough, else you will deafen your audience. You could be playing death metal of course?
Old 28th December 2011, 01:15 AM   #3
1) Your amp is capable of a certain amount of power in to a specific impedance, the manual should have that information.
2) Speakers have different sensitivities, 100 watts in to a speaker with 100 dB sensitivity (one watt at one meter) produces the same SPL (sound pressure level) as a speaker with 90 dB sensitivity driven with only 10 watts. The manual for the speakers should have at least some basic sensitivity specifications.
3) "Loud" is relative, a snare drum can produce around 120 dB SPL, a loud guitar amp is also in the same range, while a "loud" acoustic guitar is around 100 dB.
It takes 100 times the power to produce 120 dB compared to 100 dB.
4) Doubling speakers can increase the level by 6 dB, +3 dB for doubling cone area, +3 dB for doubling amp power.
That said, unless the speakers are matched and arrayed properly, doubling up on speakers actually can reduce level due to destructive interference and amplifier current limiting.
Old 28th December 2011, 02:16 AM   #4
strawberry's Avatar
Mostly the sound is too loud. I carry ear plugs in my wallet because of that.
DCX2496 in a live performance venue harpman PA Systems 9 26th January 2012 03:54 PM
Need small SET transformer (12B4) Pano Tubes / Valves 31 29th May 2009 01:04 AM
DIY2005 Orlando new venue info theNoid Multi-Way 1 21st October 2005 10:12 PM
DIY2005 Orlando new venue info theNoid Full Range 1 21st October 2005 10:11 PM
Copyright 1999-2017 diyAudio
