PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Cheap Horns
Cheap Horns
Old 13th January 2012, 09:22 AM   #11
R.I.P.
Does seeing this 10k+kHz roll-off and/or resonances indicate that a 1" throated horn driver is just too big for extended frequency response in the domestic High Fidelity duty?
I have seen just a couple of slightly smaller driver throats, but the market seems to be aimed at the PA duty. 1" and 2" throats have enormous diaphragms.
What is available in horn drivers that can extend smoothly to 18kHz and/or beyond?
Does anyone make a good (but affordable) ~30mm diaphragm with 15mm throat that can perform up to the top end of the audio range smoothly.
regards Andrew T.
Old 13th January 2012, 09:57 PM   #12
sketchyphish is offline sketchyphish  United Kingdom
sketchyphish's Avatar
Cheap Horns
Talking Okay
So right im gonna get a setup from a friend to test the speakers properly.
Ive just picked up the 19mm ply for the bass bins, so will build the system up first and then do the tests.
The horns are still in the test stages so can be changed as needed after tests
But for now got a big deco gig in Austria to do so gonna leave it for 2 weeks till thats done.
Like i said anyone got any ideas for ANY t/s specs that i can use in hornresp to model the horn i need. As well there are no specs for KENFORD.
Cheap HornsHide this!Advertise here!
Cheap Tang Band mini Horns are back! m R g S r Subwoofers 21 12th March 2013 01:29 PM
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
Horns inside of horns open foe discussion oilcanracer Multi-Way 3 15th February 2010 03:42 AM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
