PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Plywood enclosure coatings (paint, carpet, tolex, etc.)
Old 17th November 2011, 04:36 PM   #21
imix500 is offline imix500  United States
imix500's Avatar
Because it hasn't been suggested- Polane is a very popular paint for PA cabinets.
Old 18th November 2011, 02:14 AM   #22
Top Shelf is offline Top Shelf  Canada
Top Shelf's Avatar
sherwin williams right ? what's the cost on that per gallon ?
NO REST FOR THE WOOFER! 🔊😈
Old 18th November 2011, 02:39 AM   #23
cyclecamper is offline cyclecamper  United States
Top Shelf,
what's a roller brush? Is that a stucko roller sleeve or a brush?
I'm certain I'm going to put on more than one coat of duratex. I didn't buy as much as I thought; the bucket looks bigger in the picture without any size reference, and it's only 1 gallon. I want 2 coats on 2 cabinets, inside and out.
I guess I need to make some panels to go behind the recessed spring-loaded handles and I should make a router guide for the handle cutouts, but I might just use the electric hand-held sabre saw.
I really need to borrow a table saw for a few odd-angle corner braces.
Old 18th November 2011, 03:06 AM   #24
Top Shelf's Avatar
Yeah its the "disposable " sleeve that goes on the roller handle itself. A stucco sleeve may or may not be able to properly coat the Duratex onto your boxes, I suggested it because it is similar to the acrytech roller sleeve. When I first bought duratex I bought their roller sleeve and haven't looked back. I've done 6 boxes with it , and it hasn't deteriorated . It washes out very easily. Like I said that gallon pail should easily do 80-100 sqaure feet , I would definitley just do 1 coat first and try the durability. I've been using it for a year and a half and unless you're dragging your cabs across ashphalt every gig without caster wheels it'll be fine
Old 18th November 2011, 03:10 AM   #25
imix500's Avatar
Yup. I can't remember off the top of my head. I know it's more than what we use at work for cabinets from SW which is $50/gallon, but the Polane is a much harder finish.
Old 18th November 2011, 07:12 PM   #26
bartbrn is offline bartbrn  United States
West Marine -- not the cheapest (nor the most expensive), but, in my experience -- I live on Connecticut's Fabulous Vacation Shoreline! (Come see the incredible crap that floats over from Long Island!) -- and, though I wouldn't own a boat if ou paid me, they've got (of course) the whole West System, and the people who work in the store weren't selling shoes in Wal-Mart last week -- generally, they really know heir stuff. even if you're not into fiberglass/epoxy, etc. (and you should be!) check out Gougeon Brothers online magazine "EpoxyWorks" at, oddly enough, EPOXYWORKS
Check out the readers' galleries -- by no means is it all boats; it is just staggering how much incredible talent is out their, and the EpoxyWorks gallery has (off the top of my bald head) R/C boats/aircraft/cars, robotics, car stereo enclosures of the absolutely wildest design, experimental aircraft (exp aircraft forums are a great source of info on plywood, glass, carbon fiber, Kevlar, and composites of all sorts), composite cars, bicycles, motorcycles, seats... well, the galleries are just amazing, and composites (including plywood, a vastly underrated structural material) are the bomb.
Old 13th December 2011, 10:45 PM   #27
I had to reound all the outer edges on the cabinets so that the black plastic corner protectors fit correctly. Now because the corners are rounded I can't bolt on extruded aluminum angle protection (besides, some of the corners are not 90 degrees). So I was looking at some kind of rubber or plastic I could glue or staple down. One durable possibility is a "keel protector" again from the boating aftermarket. Stuff is meant to bend and shape to the hull's keel line. It uses a 2-part adhesive (primer/activator applied to surface, then the keel-guard is pre-coated with the adhesive). Any experience or advice?
Old 14th December 2011, 02:38 PM   #28
Top Shelf's Avatar
I have no expirience with that stuff but on my cabs especially with routered edges I use multiple layered fiberglass/epoxy that gets dura tex finished that way I don't worry about jigging up hardware for the edges. Hope that helps for your next box.
Old 14th December 2011, 03:06 PM   #29
Top Shelf's Avatar
Just checked on polane T ppricing, $89/ gal + tax for the main bucket and $113/gal for the catalyst but the catalyst will mix into 6 gallons of the main polyurethane. So its about $120 / gal finished. Just a thought.
Old 15th December 2011, 05:53 PM   #30
And an interesting thought. But if I was doing that I'd go for epoxy rather than polyurethane.
Plywood enclosure coatings (paint, carpet, tolex, etc.)Hide this!Advertise here!
Stacking multiple laminations of plywood to create speaker enclosure ChrisR1983 Construction Tips 10 28th July 2010 04:50 PM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
Should I paint or carpet my loudspeakers? prerunnerv6 Multi-Way 10 17th May 2006 09:31 AM
Bamboo Plywood for Enclosure pjpoes Multi-Way 24 27th October 2005 08:16 PM
Where to bet tolex/vinyl Skankadellic Instruments and Amps 1 4th August 2003 04:20 AM
