PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
balanced XLR patchbay with phase-reverse switches and ground lift
Old 17th November 2011, 10:32 PM   #11
cyclecamper is offline cyclecamper  United States
Originally Posted by simon7000 View Post
I can't look from work, but I sure will when I get home. Thanks.
Old 17th November 2011, 10:44 PM   #12
JoelS is offline JoelS  United States
Are you looking for something like this? http://www.rolls.com/pdf/M_PT102.pdf
sometimes when I do recordings with many microphones I will use something like this to check the phase of all the mics. especially when using mics that somebody else is bringing to the party, you never know if a mic is wired pin 2 hot or pin 3 hot
-Joel
Old 18th November 2011, 02:56 AM   #13
JoelS,
Yeah, that's the ticket!
or this:
Galaxy Audio CRICKET Polarity/Continuity Tester | eBay
Old 18th November 2011, 03:16 AM   #14
Unfortunately they don't make the PT102 any more.
Galaxy Audio Cricket Polarity Tester might be the only commercial product?
Old 18th November 2011, 03:28 AM   #15
http://www.youtube.com/watch?v=xZf5VkkcXQ0
Old 23rd January 2012, 03:29 PM   #16
Mike Caldwell is offline Mike Caldwell  United States
What type of application would this be used in. I would assume a fixed type of installation. I would not go to the trouble of the ground lifts and phase switches on a patch bay. If it's a splitter feeding a monitor board maybe the ground lifts could be handy, having said that my hardwired split snake has ground lifts on the monitor split and I rarely have ever needed to use any of them. The only thing I ever need to ground / pin 1 lift is the occasional direct box input and I do that on the DI with it's switch. If you would ground lift anything at your patch bay you would not be able to use phantom power on that channel.
Old 24th January 2012, 12:47 AM   #17
Speedskater is offline Speedskater  United States
Speedskater's Avatar
I definitely agree with Mike.
Kevin
Old 25th January 2012, 01:42 AM   #18
Yes, ground lift and polarity reverse aren't needed much except when you're interfacing with someone else's stuff. Still, often a switch makes the sonic differences so much easier to compare than using your sonic memory in a noisy environment while you rewire. It's just practical to use the optomitrist's approach: "better like this or better like this?" "again, better like this or better like this?"
This isn't for permanent installations; it's for making the best of what you've got on the spot.
You'd be surprised how many times I've gone into a high-end showroom and found channels not in correct relative polarity. Worse when live shows are using a mix of owned, borrowed and rented equipment.
Old 25th January 2012, 01:48 AM   #19
It's more about , the patch bay hard wiring is not the place to solve problems.
Kevin
Old 25th January 2012, 01:54 AM   #20
What board do you carry, 50 plus percent have polarity invert switches.
balanced XLR patchbay with phase-reverse switches and ground liftHide this!Advertise here!
INA134, balanced an unbalanced, normal phase and inverted phase CJ900RR Analog Line Level 1 30th March 2011 04:30 PM
A switcher stomp box that switches XLR to 1/4 Spewbag Construction Tips 2 2nd February 2011 09:25 AM
Multi-channel Ground Lift Bigun Solid State 1 20th April 2009 07:43 PM
Active DI, Ground Lift, and Me slor Instruments and Amps 3 12th April 2008 09:43 PM
What means ground lift? Bassterror Solid State 11 16th January 2008 10:14 AM
Copyright ©1999-2017 diyAudio
