| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
#11 |
Because a loudspeaker's impedance can drop to 1/2 the rated value at some frequencies.
#12 | ||||
Speakerholic
![]() Hmm... ![]() Quote:
![]() Quote:
![]() Quote:
![]() I love diyAudio
#13 |
Its like a minefield
#14 |
There's the quality of the drivers to consider; something with a cast frame probably has a more honest power rating. Most of your amp power goes into heating the voice coils, so the trick is to get rid of that heat. Apart from the burning out problem, heat also affects the resistance of the voice coil, causing "power compression". Vented pole pieces, bigger diameter voice coils, vented gaps all help (and cost more).
And the dynamic range of the program material. While harmonics from clipping are traditionally blamed for blowing tweeters, according to this paper from Rane it is just that the dynamic range is effectively reduced so much more real power is delivered. To use a bad analogy, you can fit a lot more cornflakes in a box if you crush them first. http://www.rane.com/pdf/old/note128.pdf Last edited by dangus; 3rd November 2011 at 11:21 AM. |
| Daisy Chain Monitor Speakers | msaffer | Multi-Way | 3 | 20th April 2010 05:05 PM |
| daisy chaining an electronic crossover | qguy | Subwoofers | 5 | 14th January 2007 01:53 PM |
| Daisy chaining 2 PCM2902's | djd4n | Digital Source | 4 | 2nd August 2004 03:03 AM |
| Daisy-chaining power cables | ftjandra | Parts | 3 | 8th July 2004 03:46 AM |
| Daisy-chaining transformers | Wingfeather | Parts | 13 | 13th May 2003 11:30 AM |
