Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 11th February 2013, 11:32 AM   #101
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Yes, that's the point.
And it will be LOUD !!!
Old 11th February 2013, 11:43 AM   #102
picowallspeaker's Avatar
Loud is not a quality
Old 11th February 2013, 12:19 PM   #103
tinitus is offline tinitus  Europe
that depends
Old 11th February 2013, 12:33 PM   #104
Sure, why not, it depends...
It's called intensity of the sound Vs distance
Old 11th February 2013, 06:10 PM   #105
chrispenycate's Avatar
Why is it being assumed that a "pro woofer" is a PA speaker? Just because we're in the live sound, PA section?
After all, I work in a studio. Are my studio monitors not professional? One thing is obvious, a large percentage of their ancestry comes from cinema speakers – but so does a lot of PA technology. And, for that matter, most of HiFi and computer speaker systems, although quality might not be maintained across the range.
If drivers are well matched, what matter if they were originally designed for one function or another? And multiamping can match speakers that would have been exceedingly problematic in my youth.
Perhaps one could generalise that touring PA subwoofers tend to have stiffer suspensions than drivers intended for fixed listening (be that installation PA or home systems), so the voice coils show less of a tendency to bang against the magnet during transport, which means that for a given cone area they tend not to go so far into the bass, and certainly they are usually higher efficiency, so the amplifier doesn't have to work so hard (and thus frequently sounds better, although hum and noise are increased) but this isn't a reason to reject them out of hand.
A good studio monitor system, a good PA system, can give high quality sound, and reproduce a more realistic dynamic range (assuming you have tolerant, distant or deaf neighbours) than anything but an economically unthinkable HiFi set up.
Ok, it might seem silly that your low end can deliver 124 undistorted dBs, while your mids and highs struggle to give 98, but 5.1 in cinemas demonstrates that reserve low frequency power can enhance the listening experience considerably.
Old 11th February 2013, 06:24 PM   #106
old story
since we don't know the difference it won't matter either
but you are not going to say in-wall speaker are also pro speakers, are you ?
but I guess they actually are, stricktly speaking
hey, just joking
but what is PA, bass guitar, or studio woofers...its not so simple any more
I suppose more a matter of where you use them, and the way you design
Old 11th February 2013, 06:28 PM   #107
cbdb is offline cbdb  Canada
Fletcher Munson.
This thread has the wrong title, it should be PA drivers not Pro drivers. Pro drivers include Genelec (and other pro studio monitors) that you would never see in a PA.
Old 11th February 2013, 09:22 PM   #108
JackNZ is offline JackNZ  New Zealand
@chrispenycate
This is exactly whatI wanted to say.
There seems to be the general opinion that a P.A. speaker is loud and a home speaker is not but sounds good.
First of all a decent P.A. speaker is out of the price range where people play around at home. So when someone here tryed out a P.A. speaker and did not like it, it would possibly not have been a expensive chassis from 18 Sound, B&C or maybe PHL. but something like this Dayton mentioned by the threadstarter or some cheap speakers from Emminence. Those drivers are cost optimized and can take some abuse because they are designed with a stiff suspension and a underhang voice coil to not excurse to much.
There is no inductance control ring nor sophisticated cone design. Also those speakers are not manufactured to low tolerance because that would rise production cost. But that's where good sound comes from at the end.
So a top range Scan Speak or Vifa or Morell 8" chassis will outperform the
cheap 12" driver even if it says "pro" on the box it came out.
But take a top line 18Sound or BMS 6" with long excursion and high BxL and the story looks totally different.
It is a fact that there are good sounding speakers on the market and you can divide them anymore between pro and home. There are also good designed ceiling speakers:-)
Old 11th February 2013, 09:40 PM   #109
Speakers, though very important, are just part of the problem of sound reproduction
Old 12th February 2013, 01:18 AM   #110
But then we should say there's no problems, only solutions;-)
ROCKFORD PRO 301 SP a bad right channel (burns TC11) josesony68 Car Audio 25 5th August 2011 07:26 AM
Using a home preamp with a pro audio power amp SoundLogic Parts 9 24th February 2011 03:04 PM
Home and pro audio equibment interconnect Vetal Solid State 5 17th September 2010 11:10 PM
Pro Audio Equipment In the Home CARTRulz Subwoofers 59 25th June 2006 05:09 PM
Problem using Pro amp with home receiver Phatman91624 Subwoofers 5 9th August 2005 11:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
