PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Why is a pro woofer bad for home use?
Old 22nd June 2013, 10:31 PM   #161
slr 5000 is offline slr 5000  Australia
I've used both pro and home drivers in the same and separate setups
with some very expensive scan speak and eton drivers amongst them
I now only use pro drivers
and the assumption that they don't do well at low volumes is rubbish you just have to choose the right drivers same as any build .they are not all large xmax/motor designs
look to altec ,phl, ae etc.
Sheafer
Old 22nd June 2013, 10:33 PM   #162
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I always enjoyed utterly baffling individuals who take a listen to a pair of high efficiency loudspeakers I've built.....the pair all alone in the middle of the room. I'd hear the "What's hooked up to it?" yelling over the music....I'd pick up the FM "Walkman" half the size of a pack of cigarettes running some milliwatts into the enclosures. I'd get the weirdest looks!
__________________________________________________ _____Rick.......
Old 22nd June 2013, 11:01 PM   #163
yes much more freedom with amplifier choice
there are some real gems if you don't need much power such as the first watt stuff ,hiraga and various tube designs
Sheafer
Old 23rd June 2013, 04:27 PM   #164
TerryO is offline TerryO  United States
TerryO's Avatar
Basically there are a lot of disadvantages to low effeciency speakers. I've heard some that sounded fine, but I have never associated the sound quality with low effeciency. High Efficiecy speakers have a lot of advantages and the only downside being that poor quality electronics are shown for what they are. So if you're using Lousy (but powerful) amplifiers, etc., be sure to use Low Efficiency speakers...Your ears will thank you!
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 14th July 2013, 12:21 AM   #165
art64 is offline art64  United States
I'm using 2 Crate 2 x 15 guitar bass cabs as my speaker system. The bass cabs have 2 15" Eminence Delta each cabinet. I added an Eminence horn twitter for high frequency. The twitters are connected through Eminence 3-way cross over, but the woofers are not. They are running without passive cross overs.
But, I'm using a Bose 901 Series IV active cross over between the pre-amp and power amp. Sounds freakin great. Not harsh for for home use and can be played at low volume levels and still have good bass and treble. The mid bass and mid frequencies are excellent. The sound doesn't sound thin at all like the Infinity SM-150 and other DJ speaker systems.
Yes, I have Bose 901 speakers. And as far as the active equalizer, they are set a bit below their mid settings. My pre-amp bass and treble control settings are also set below mids. I'm using Yamaha C80 and m80.
Old 20th July 2013, 02:16 PM   #166
Jimmy154 is offline Jimmy154  United States
Jimmy154's Avatar
Originally Posted by sippy View Post
EmKens are a wide range design though - GF is slightly worried about my plans for LF reinforcement as the enclosures are going to be HUGE
I'm not sure I should give relationship advice, but you need a new GF.
This is just the tip of the iceberg. She's not even your wife and she's telling you what speaker to build. Not a good sign. She's going to have a problem with everything. And if you marry her it will be worse.
PM BOX IS FULL
Try ----> gtlucko (4T) gmale
Old 20th July 2013, 11:04 PM   #167
JackNZ is offline JackNZ  New Zealand
She just looks at it from a girls point of view.
You can be glad she listens to your plans at all..
Btw., subs don't have to be huge, today good speakers and poweramps come cheap, so you can build small and tune low and then boost at Fb.
sounds good and is much less to carry.
Old 29th December 2016, 02:27 PM   #168
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Wow, look at the freq response Of this driver Troels mentions on his site! A 15" woofer that would actually work well with a 1" horn driver or smallish full range driver
If you point it at you!
http://www.parts-express.com/pedocs/...ifications.pdf
Originally Posted by Jazz36 View Post
It's my variation on OBL-15 by Troels Gravesen OBL-15
woofer speaker and mid-range speaker old one USSR made, mid-range speaker modified,
tweeter Dayton Audio AMT 3-4
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 29th December 2016, 02:38 PM   #169
6L6 is offline 6L6  United States
6L6's Avatar
Wow... that really is good. I wonder if the big wood TAD horn is still available?
Old 29th December 2016, 02:49 PM   #170
diyAudio Editor
Variac's Avatar
Make one!
Why is a pro woofer bad for home use?Hide this!Advertise here!
ROCKFORD PRO 301 SP a bad right channel (burns TC11) josesony68 Car Audio 25 5th August 2011 07:26 AM
Using a home preamp with a pro audio power amp SoundLogic Parts 9 24th February 2011 03:04 PM
Home and pro audio equibment interconnect Vetal Solid State 5 17th September 2010 11:10 PM
Pro Audio Equipment In the Home CARTRulz Subwoofers 59 25th June 2006 05:09 PM
Problem using Pro amp with home receiver Phatman91624 Subwoofers 5 9th August 2005 11:53 PM
Copyright ©1999-2017 diyAudio
