PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Why is a pro woofer bad for home use?
Old 28th April 2013, 10:44 AM   #131
JackNZ is offline JackNZ  New Zealand
Could be quit complex to crossover that, aye.
Old 28th April 2013, 10:16 PM   #132
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
even if not complex, simle can be difficult too
not so hard to throw out a design....but xo values would take me half a year to get the balance right
Old 28th April 2013, 10:27 PM   #133
Doesn't have to be that long, just 2 1/2 way design suffer from phase problems due to the two woofers having different low passes and because of that not summing properly and generating lobes in the vertical plane.
Specially if you use high efficient drivers like you suggested which require higher order x-overs.
Old 2nd May 2013, 02:59 AM   #134
perempe20 is offline perempe20  Hungary
perempe20's Avatar
Originally Posted by tinitus View Post
might be possible to combine a 10" and 8" in a 2.5way design
(with similar low end rolloff)
last time i've heard a 6.5" (M17WH-09 without any component + a dome tweeter) with a 10" (M25WO-49, second order xo with 4.7mH+47F), and I did not like it. okay, they were hifi speakers.
Old 2nd May 2013, 05:50 AM   #135
Veronica is offline Veronica  United States
Veronica's Avatar
Send a message via Yahoo to Veronica
Originally Posted by JMFahey View Post
I had to scroll back to see what the fuss is all about.
Found nothing to complain about.
I had expected the typical ALL CAPS FULL OF BRAGGING OR BAD KARMA post we find now and then, which are all but unreadable and cause headaches, but it was not such.
In fact, I found it quite well mannered and to the point.
Caps are one accepted form of EMPHASIS, same as writing between *asterisks* or >like this< or _this_ other way.
In fact, they precede Internet by a long way (as in a couple thousand Years) .
Not forgetting that re-EMailing text (such as Forum EMail notifications) *often* strips text of "font attributes" and meaning sometimes gets lost.
They do the same on "smilies"
By the way, Veronica wrote this one year ago, don't think she's exactly monitoring this thread by now
LOL No, sure wasnt....just now catching up 2 months later!
(I couldn't hear the notification over the music here).......
My two cents. Actual retail value based on imaginary hypothesis.
Old 2nd May 2013, 05:58 AM   #136
Veronica's Avatar
Originally Posted by qusp View Post
Veronica, interesting post, but do you think you could tone down the SHOUTING? or you are trying to be heard over the pro woofers? try bolding, or underlining its less in yer face
See now when you read ONE word in caps that is emphasis. When it is a whole sentence, that is shouting.
How can you read a single word in caps in a whole sentence as a shout?
Probably bold or underline is better. Okay, duly noted. (However this is really focusing on the minutae instead of the message).
Old 20th May 2013, 11:22 PM   #137
A 6.5" 'without any component' will breakup and start to radiate very narrow above lets say 2k. So of course you will not like it. Why should you do that?
Who knows how the response of that system was. Who kows how summation was.
I suggest not to do such experiments because it is a waste of wood and time.
There' a theory behind our hobby. There is a history. There was people who
Researched and described the phisical behavior of speakers and propagation of soundwaves.
It is all written and when you deviate from the basics, you will build expensive
toy that will not at all sound as good as the components of it could when used
right. It is just a waste of time and money to put speakers in a box and try to
hook'm up maybe swap the red and black wire and then listen whats happening.
Our hearing and the ear to brain system is too adaptive to elaborate a crossover
by listening to music and change values randomly and see if you like it more that way, as long as you keep violating the simplest roules like operating a driver outside of its specs.
Be careful to listen to people who want to tell you to not use equalizers because of phase distortions. To not use crossovers because of similar problems.
Those people mostly just improvise and try to sell there limited knowlege.
Old 17th June 2013, 05:44 AM   #138
audiocom is offline audiocom  Portugal
Biggest problem is when u need to hear at low levels. Pro woofers NEED power to displace them and tend to be inaudible at very low power inputs, as surroundig coat is too hard to move with it.
Old 17th June 2013, 09:39 AM   #139
Pro woofers are usually very sensitive compared to non pro.
They do not need extra power to make them audible.
I would contend they need less power to make them equally audible to most non pro drivers.
regards Andrew T.
Old 17th June 2013, 06:24 PM   #140
chris661 is offline chris661  United Kingdom
chris661's Avatar
This is so very dependent on so very many factors that you could draw any conclusion you like, and it'd be easy to find a driver/cabinet/frequency combination that suggests the opposite.
I'm not sure I'd bother starting: that way lieth madness.
Why is a pro woofer bad for home use?Hide this!Advertise here!
ROCKFORD PRO 301 SP a bad right channel (burns TC11) josesony68 Car Audio 25 5th August 2011 08:26 AM
Using a home preamp with a pro audio power amp SoundLogic Parts 9 24th February 2011 04:04 PM
Home and pro audio equibment interconnect Vetal Solid State 5 18th September 2010 12:10 AM
Pro Audio Equipment In the Home CARTRulz Subwoofers 59 25th June 2006 06:09 PM
Problem using Pro amp with home receiver Phatman91624 Subwoofers 5 10th August 2005 12:53 AM
