PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Why is a pro woofer bad for home use?
Old 27th April 2013, 08:53 AM   #121
nannoo is offline nannoo
Can I clarify, when we talk of Pro-Audio, are we referring only to PA (sorry, public address) or studio monitors aswell?
Because the first mind blowing pair of speakers I heard were the in-wall main studio monitors back at RG Jones recordings studios in wimbledon (now sadly closed), Which I would have described as 'Pro Audio'.
When I worked in a live music venue, we (myself and my sound engineers) would use the main PA system to listen to newly purchased, newly recorded, and favourite music. It was amazing, and although not true high-fidelity, I'm sure if we tweaked the system to a 'home use' type set-up, it would have easily achieved it.
Old 27th April 2013, 09:35 AM   #122
JackNZ is offline JackNZ  New Zealand
I think that the whole discussion is questionable. Someone heard a speaker he refered as pro speaker to. Pro audio systems are tuned to have a linear frequencie response and can sometimes sound hard. Especialy when played loud.
Old 27th April 2013, 09:40 AM   #123
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
may be so...or it is what you make of it
Old 27th April 2013, 09:43 AM   #124
Out of experience in designing speaker systems for professional use frequency response in the important range between 1 and 4 KHz decides about how good the system sounds with music playback.
Old 27th April 2013, 10:09 PM   #125
perempe20 is offline perempe20  Hungary
perempe20's Avatar
would you recommend a 12" woofer for similar application (studio monitor)?
Old 27th April 2013, 10:20 PM   #126
2.5way, MMT with 2x8" plus tweeter, and a mono sub with 18" woofer
Old 27th April 2013, 10:56 PM   #127
12" starts to narrow coverage from 800 Hz upwards. So need 3-way or very low x-over. 8" similar problems.
Old 28th April 2013, 03:13 AM   #128
perempe20's Avatar
example? what woofer/tweeter do you recommend?
Old 28th April 2013, 05:57 AM   #129
ouch...I just jumped out on thin ice
maybe use 2x 8PR200
FaitalPRO | LF Loudspeakers | 8PR200
though Eminence Beta8 would be much cheaper
tweeter ?...dont know exactly
maybe one of these
FaitalPRO | HF Drivers | HF100
FaitalPRO | HF Drivers | HF105
FaitalPRO | HF Drivers | HF106
FaitalPRO | HF Drivers | HF107
woofer ?
maybe this new 18"
http://www.faitalpro.com/products/LF...p?id=201070138
Old 28th April 2013, 06:02 AM   #130
might be possible to combine a 10" and 8" in a 2.5way design
(with similar low end rolloff)
Why is a pro woofer bad for home use?Hide this!Advertise here!
ROCKFORD PRO 301 SP a bad right channel (burns TC11) josesony68 Car Audio 25 5th August 2011 07:26 AM
Using a home preamp with a pro audio power amp SoundLogic Parts 9 24th February 2011 03:04 PM
Home and pro audio equibment interconnect Vetal Solid State 5 17th September 2010 11:10 PM
Pro Audio Equipment In the Home CARTRulz Subwoofers 59 25th June 2006 05:09 PM
Problem using Pro amp with home receiver Phatman91624 Subwoofers 5 9th August 2005 11:53 PM
Copyright ©1999-2017 diyAudio
