Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 6th October 2011, 09:17 PM   #11
How about these:
BMS - Thomann UK Cyberstore
Old 6th October 2011, 09:44 PM   #12
celsosc is offline celsosc  Portugal
Very good too, but the BMS diaphragm has no dome
http://www.thomann.de/gb/search_GK_palplkdp_BF_bms.html
Old 8th October 2011, 08:39 PM   #13
Pano is offline Pano  United States
Pano's Avatar
You're in Italy. Shouldn't you be looking at FaitalPro and 18Sound?
Old 9th October 2011, 05:50 PM   #14
Hi ! I will look at those brands you mention
I am trying to trace down the brands which offer the best Q/P ratio
gino
Old 9th October 2011, 05:53 PM   #15
Pano's Avatar
Faital may be hard to beat, there. Also look at Selenium from Brazil
Old 10th October 2011, 04:56 PM   #16
Thank you for your suggestion !
Actually I live in same area of the factory
I will call them and check prices.
Kind regards,
gino
Old 3rd November 2011, 05:58 PM   #17
dirkwright's Avatar
[QUOTE=ginetto61;2725058]
Originally Posted by pinkmouse View Post
If you can slightly alter your plans and find a good mid that will go up to about 2.2K, then for the price you can't beat the B&C DE10, a cracking little driver for the money.
Thank you for your kind suggestion
Actually I see a very good response curve
At this stage, I have just started asking for suggestion, I can alter pretty much everything
I know that the midrange is the more critical range
I have not decided yet for a cone or a dome midrange driver.
I would like to go with just two ways but I understand the huge difficulties in this approach with only to drivers that must cover the all spectrum
There are commercial speakers doing this but usually they come very very expensive
Thank you very much again
Kind regards,
gino
If you've got the money, the B&C DCM50 should be an awesome midrange. You'll need a really big horn to go with it though.
High vs. low compression ratio in horns Defo Multi-Way 27 4th June 2010 03:02 AM
Compression ratio and diaphragm size in compression drivers inkasound Multi-Way 50 8th January 2009 03:38 PM
looking for good compression drivers mahalta Forum Problems 0 19th May 2008 12:58 PM
FS - BMS 4552nd Compression Drivers - Brand New (Australia) Rialb Swap Meet 16 5th February 2008 09:37 AM
Good 2" compression drivers? imix500 Multi-Way 12 6th July 2005 06:01 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
