PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Help with Behringer CX2310 crossover
Old 7th November 2012, 12:45 AM   #21
turk 182 is offline turk 182  Canada
Daves Not Here
reminds me of someone that used to a sound company in nortern ontario i might be wrong but...
Old 13th February 2013, 05:24 PM   #22
mustangguy is offline mustangguy
Default Crossover, amps & Mixer setup
Im new at this & Im trying to set up a sound system at my place for family gatherings and such. Could anyone direct me as to how would I connect the following equipment?
Thank you very much for your time and patience.
XENYX 1222FX Mixer
BEHRINGER CX3400 PRO AUDIO DJ 3 /4 WAY ELECTRONIC CROSSOVER
1 Crown Powerbase 3 Amp
1 Behringer EP2500 Amp
2 Behringer B212XL Speakers
2 Behringer EUROLIVE VP1800S Subwoofer
Old 12th November 2015, 02:10 PM   #23
Paul wheatley is offline Paul wheatley
I have just purchased the Cx2310 I'm currently running a Numark CD1 mixer to my Berhinger EP4000 amp with 2xPeavy 15" black widows and 15" wharfedale sub could any body tell me the best way to wire up and connect my new CX2310 into my existing system my mobile is 07956822325 if you could possibly explain by text or whatsapp with diagrams if possible thanks Paul wheatley
Old 19th November 2015, 07:38 PM   #24
djstan is offline djstan  Canada
Default Don't buy Behringer
I got rid of my Behringer X-over when it started cracking everytime I turned up the bass on my DJ rig. Sounded like the speaker was limiting. Turned out it was the x-over. Probably some kind of circuit board fault. Quality control just not good enough. Trashed it.
Old 20th November 2015, 02:37 AM   #25
conanski is offline conanski  Canada
For all you guys looking for help setting up these Behringer crossovers.
The first thing you do if you haven't done so already is open or download a copy of the manual from the manufacturers web site and study it.
The go to the rear of the crossover and set the mode switches in the middle for whatever configuration you want, 2-way stereo, 3-way stereo, 4-way mono, etc.
Then turn the unit around and power it up and you will see the LEDs lit above the controls that are necessary for your use, ignore everything else.
Then just follow the directions in the manual and don't be afraid to experiment, there is no right or wrong.. if it sounds good it is.
Basic crossover starting points are 80-120hz for subs to mains and that will work for any type of sub, if you're doing a 3 or 4 way the crossovers are dependent on the drivers and cabs being used, this is a more advanced setup that requires specific advice.
Help with Behringer CX2310 crossoverHide this!Advertise here!
Behringer CX2310? Cal Weldon Multi-Way 15 25th November 2011 05:10 AM
behringer cx2310 hillbear Analog Line Level 0 27th October 2010 01:27 PM
FS: Behringer CX2310 two-way active crossover nl Swap Meet 1 10th June 2009 02:06 PM
FS: Behringer CX2310 active crossover plus 2x PEQ2200 parametric equalizers nl Swap Meet 6 21st May 2009 03:58 PM
short DC when turning on and shutting off Behringer cx2310 crossover keyser Parts 3 1st February 2005 09:37 PM
