| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
#31 |
Proud Union Member
6BG6GA, I totally see where you are coming from. However, based on the info given I think the assumption is that this hotel has minimal A/V support.
Ether, please correct me if I'm way off base there. There's a good chance it's either maintenance or custodial staff that are charged with setting up the risers and plugging the mic in the wall. If a remote panel was installed to recall presets of a delay line processor, chances are it would rarely if ever be touched and the delay zones would do more harm than good. I've done systems both ways with good results. I think it's all about the bigger picture. (Since we're tossing around credentials, look up large sound companies in Yonkers NY and that will give you an idea where I'm coming from) |
#32 | |
Well gentlemen what I suggested is how I would have done it given the chance and a usable budget.
As for the RT 60 times based on a program.... my experience has been that sometimes they are correct but most times they aren't correct. I take equipment to measure RT 60 times. Quote:
I would use the first row of speakers by the stage at no delay and start delaying each row as I moved away from the first or primary row of speakers. This way one seems to have the illusion that the sound is coming from the front instead of getting hit first from the speakers above your head and then from the speakers in the row ahead of that and so forth. Experience has taught me that this method works far better that just throwing up a 70.7 volt line of speakers and paralleling them all together. Granted delaying them for music like background Muzak in a different mode of operation would be of no value what so ever.Some do not add delay lines as I will call them when using ceiling speakers. Delay is not just used when employing speakers on stands up front or speakers on stages. If the budget isn't there then throw up the 70.7 volt speakers with no delays. I would however suggest a decent EQ like a Shure DFR22 to eq and to set feedback filters. However the amount of speakers suggested by the poster needs to be doubled in order to have some decent coverage with some overlap. I do suggest the 70 volt speakers over using 8 ohm with a series parallel config. Note the 8 ohm speakers would require much much larger wire or smaller gauge that what the 70 volt system would. With the 70 volt one could easily get by with 18 ga wire. Last edited by Original Burnedfingers; 17th August 2011 at 11:09 AM. |
#33 | |
Hook a PC straight to a mix board and see what you get. What I suggested (the Edcor) is what I use from the PC to the board. Save the DI box for other uses. Sorry if I didn't clarify what I meant. |
#34 |
So let's recap:
That should give you some good points going forward. We don't know how much room you have in your money and time budget to change things. Knowing that would help us help you.
Take the Speaker Voltage Test! |
#35 |
Get some sort of DI, transformer or interface to connect computers to the mixing console via the installed mic lines. Direct box for interface from mic jack at stage for computer, line source Something like the Edcor to connect a computer to the mix at head end via Aux input on board or line in on a channel. |
#36 |
#37 |
What do you use to make the measurement?
Tef analyzer Last edited by Original Burnedfingers; 18th August 2011 at 11:41 AM. |
#38 |
#39 |
If I get a chance I will check the model. Its one of the first if I remember.
#40 |
I use these at work. Very $$ though. Never a problem with them.
Radial Engineering - ProDI / ProD2 passive direct boxes |
| Advice on a new pa system | sbattersby 115 | Instruments and Amps | 12 | 4th August 2009 02:00 PM |
| n00b PA problem question | agothacles | Solid State | 4 | 16th December 2008 04:50 PM |
