High quality 2-way (15" + CD) PA speaker design - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 14th July 2011, 12:47 PM   #1
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
Default High quality 2-way (15" + CD) PA speaker design
Hi all, I'm helping a friend design and build a what we hope will be a good quality and versitile PA reinforcement speaker.
For larger venues, these would be used with a subwoofer setup, but smaller venues they should be able to cover on thier own. High SPL and high quality are important factors, it would also be desireable to be able to expand the system to cover large outdoor crowds without moving to full line array setup, if this would be possible.
We have selected some drivers we think will be suitable for this design. They are:
Woofer - RCF MB15N351
Compression driver - Beyma CD10Nd
Horn - Beyma TD194
The horn + CD for thier high sensitivity and ability to crossover quite low, and the woofer for its relatively high sensitivity and extended response. The lightweight neo motors are an advantage.
A logical crossover point is going to be around 1.5kHz. There are a few issues I can see. Obviously, the CD is quite lot more efficient, so an L-pad will need to be used. In a high power setup I am concerned this could waste a lot of power? However, a lower efficiency CD is going to limit max SPL, which is worse.
The woofer has a bit of breakup around 2kHz, it won't be massively attenuated by a 1.5kHz crossover (probably 12dB/octave). Would it be applicable to run a 1.2kHz (or whatever frequency is determined best) crossover on the woofer and 1.5kHz on the CD, thereby the rising output caused by the woofer breakup is smoothed out by virtue of it having a crossover beginning earlier. Or does doing this ruin the phase response of a crossover?
On phase, naturally the CD sound eminates from a point further back than the woofer, ie, the throat of the horn. What can be done to help preserve a coherent wavefront? A whole wavelength at 1.5kHz is ~23CM, the whole horn path is 14.5CM, so it's possible the spacing between acoustic centres of the woofer and CD is around 1/2 wavelength at this frequency. This means the drivers should hence be wired in phase, not out of phase as is typical in 12dB filters? The exact crossover point should be adjusted for phase coherence?
The TD194 horn is chosen for its 90x40 degree coverage. With relatively limited vertical coverage it is hoped that multiple speakers could be used to get more crowd coverage without treble cancellation issues. How will such a horn interact with the 15" woofer though in terms of dispersion?
The woofer will logically be installed in a vented enclosure. Around 45L tuned at 70Hz looks nice. Not much low bass, but suitable for crossing to subs and enough for smaller venues I'd think:
With regards to the cabinet, how important is shape? Many commercial designs are trapezoid, is this very important for reducing resonance? I guess not so much stuffing material can be used as with Hi-Fi since the heat build up could be significant. Bracing too I guess will remain important.
Baffle step correction I assume is best taken care of before the amplifier, actively, to save power. An EQ or the active crossover should facilitate this. Unless someone knows of a neat way to integrate this into the speaker?
That turned out to be a bit of a long post! Any input is appreciated. This design must exceed the JBL MRX515 in quality and SPL as it will cost more, and if a full design can be developed they shall be built ASAP.
Old 14th July 2011, 02:17 PM   #2
keyser is offline keyser  Netherlands
keyser's Avatar
A lot of questions!
For a design like this I would probably opt for a 2" compression driver. It will allow you to cross lower and/or it has more dynamic headroom. This comes at the expense of some top end dispersion but the lower crossover point will give you better directivity in the all important midrange. And please do use a bigger horn. The bigger the horn, the lower the frequency to which horn-loading works and the lower the frequency to which directivity control is maintained. I would use the biggest horn that still fits on the baffle.
Padding the tweeter shouldn't be much of a problem.
The relative delay difference between drivers has to be dealt with in the crossover. This might take some effort to get right. Do you have experience with designing crossovers?
Cabinet shape is not very important. There is no need to be afraid of the inside of the box getting too warm due to acoustic damping. The sound power is small in comparison to the electrical power dissipated in the voice-coil.
If you have EQ, I think it's a good idea to do most corrections that way.
Keep in mind though, that it might be difficult to build something a lot better than a JBL MRX515. Those are pretty good speakers at a good price!
Dutch & Dutch
Old 14th July 2011, 02:38 PM   #3
AllenB is offline AllenB  Australia
By what criteria did you choose to cross at this point? I ask as I think it would answer some of your other questions.
You want to match phase between the drivers, obviously, and it can be done. Would you be planning to measure? to simulate?
Old 14th July 2011, 02:45 PM   #4
Dr_EM's Avatar
Thanks for your response!
To change to 2" CD and larger format horn without going over budget leaves only 1 real choice of components:
P-Audio BM-D750 Compression driver
PH-2380 Horn
These are presumably not such high quality components but I suppose this may be outweighed by being able to use a lower crossover point. High frequency extension also takes a hit.
I don't have experience with passive crossovers so would need some guidance on this. Am I thinking along the right lines with adjusting the crossover frequency until we can use the driver in reverse polarity to achieve a coherent wavefront?
I'm not concerned with the wadding absorbing acoustic energy and gaining heat, only that it may impede the cooling of the driver motors by insulating the enclosure. I suppose with it being vented though that this circulates cooler air.
I suspect you're right with the JBL speaker. Where there are savings to be made in building your own PA subwoofers, this may not be the case for full-range speakers.
Old 14th July 2011, 02:53 PM   #5
dirkwright's Avatar
PH-2380 Horn
I don't think that driver is going to help you. I think the other poster was referring to the $200+ 2" compression drivers that can cross over at 500Hz. This driver can only cross over at about 1 kHz.
Also, my limited understanding is that for maximum power output, you're going to have to go active, with 24 dB/octave filters. This of course significantly increases your cost.
Old 14th July 2011, 03:02 PM   #6
keyser's Avatar
Actually, I think a 1khz crossover might be about right for a woofer this size. Some 1" drivers can handle it reasonably well, but a 2" driver might be better suited. If you want to use a 2" down to 500 hz, you'd need a huge horn!
The P-audio's look well suited at first glance.
Dutch & Dutch
Old 14th July 2011, 03:12 PM   #7
dirkwright's Avatar
I would go with this:
http://profesional.beyma.com/ingles/pdf/CP750Nd.pdf
on this horn:
http://profesional.beyma.com/ingles/pdf/TD590.pdf
crossing over at 800 Hz.
Old 14th July 2011, 03:15 PM   #8
Dr_EM's Avatar
1.5kHz was only chosen preliminary as a point that the CD+Horn could comfortably run down to.
I think simulation and calculation is more likely than measurements, though I may be able to take some measurements.
The horn for the P-audio is about the largest one could fit onto a design like this. Achieving a lower crossover point in this size format is probably not going to be possible. So, is 1kHz with this large 2" CD and horn a much better choice than 1.5kHz with a 1" CD and smaller horn? Will the 1" CD "bottom out" at its max 70W toward the lower end?
Old 14th July 2011, 03:19 PM   #9
dirkwright's Avatar
The horn for the P-audio is about the largest one could fit onto a design like this. Acgieving a lower crossover point in this size format is probably not going to be possible. So, is 1kHz with this large 2" CD and horn a much better choice than 1.5kHz with a 1" CD and smaller horn? Will the 1" CD "bottom out" at its max 70W toward the lower end?
The horn I picked is 250x 280 whereas the one you originally picked is 202 square. Is that a large difference? Both are far smaller than a 15" driver.
Old 14th July 2011, 03:28 PM   #10
Dr_EM's Avatar
Sorry, you must have posted while I was typing. Those are nice components, but a stretch too far budget wise. Looking at around 340 on drivers per cab; that CD+Horn leaves 0 budget for a woofer unfortunately.
FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 nl Swap Meet 2 10th June 2009 11:15 PM
hassles with 15" PA speaker Dan2 Solid State 5 28th April 2009 03:10 PM
High Quality 15" Drivers for SQ... chops Car Audio 13 18th November 2008 03:12 AM
15" PA Driver PB2 Multi-Way 2 15th August 2008 11:20 PM
Reasonably priced 15" PA woofers in Canada? Cal Weldon Multi-Way 11 2nd January 2007 09:41 PM
Copyright 1999-2017 diyAudio
