| PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc. |
#11 |
I'm not sure about bottoming out a 1" CD. The problem with the higher crossover point is the change in directivity: the 15" woofer beams a lot at 1.5k, while most horns beam a lot less. At the crossover you want to match the directivity of both drivers.
"Convictions are more dangerous enemies of truth than lies" - Friedrich Nietzsche Cardioid-like + Waveguide 2-way |
#12 |
Sounds logical yes. The JBL system uses a 1.7kHz crossover interestingly. Not too sure why it has 70x70 radiation horn either, surely wide horizontal and narrow vertical is always more desireable in this sort of application?
With no off-axis graphs or polar plots for the RCF 15", how can we determine what a good crossover point should be? Would you say 1kHz is a good general frequency for a 15" to match the 90x40 horn? |
#13 |
They are cheaper here in America. Maybe someone can smuggle them into the UK for you?
#14 |
1kHz is a good start, probably not any higher. If you don't want to go down with the horn, you could think about smaller woofers.
#15 | |
For a 90x40 to maintain vertical pattern control to 1000 Hz, the mouth needs to be about 12" high (a full wave length of 1K), which presents other design difficulties and compromises. All front loaded cone speakers begin to beam at a frequency dependent on the piston diameter. A 15” has a -6 dB 90 degree dispersion at about 1200 Hz. Dispersion varies with frequency, a 15” speaker is about -6 dB at 60 degree at about 1.8K, a 12” at 2.2K, a 10” at 2.8K. A 15” has a 180 degree -6 dB beam width at around 600 HZ, a 12” at about 800, and a 10” at about 1200 HZ. A 12” speaker is around 180 degree at 900 Hz, 90 degree at 1200 Hz, 50 at 2400 Hz, and 30 degrees at 4000 Hz. |
#17 |
Thanks for all the input, it's been very useful! Currently, my friend is having trouble raising money for this project. He needs to sell a pair of 3015LF drivers to get some funds. I say it's a shame they aren't the standard 3015 model as those would probably work in this design!
#18 |
PD153er from precision devices....+ something like CP750nd or CP800 ......
Good combination Regards, Taj |
| FS: Vintage high-Qts 15" woofers like Eminence Alpha 15 | nl | Swap Meet | 2 | 10th June 2009 10:15 PM |
| hassles with 15" PA speaker | Dan2 | Solid State | 5 | 28th April 2009 02:10 PM |
| High Quality 15" Drivers for SQ... | chops | Car Audio | 13 | 18th November 2008 02:12 AM |
| 15" PA Driver | PB2 | Multi-Way | 2 | 15th August 2008 10:20 PM |
| Reasonably priced 15" PA woofers in Canada? | Cal Weldon | Multi-Way | 11 | 2nd January 2007 08:41 PM |
