Hello, I'm fairly new to speakers and brand new to this forum and I'm in need of some advice. I have a pair of Acoustic PA mains I bought used off a guy and after maybe 40 shows, sound went out on one and months later on the second.
I can't find any information on these speakers online or on the speaker box so I don't even know what wattage rating they have. Each PA speaker has a hefty metal horn and two 'black widow' 15" speakers. The speaker's don't look ripped at all, and the crossover fuses don't look blown either. I've double checked connections, wire quality, and my power amp and signals and all I am getting is no sound in one speaker, and in the other, there is a very very faint sound signal coming through the horn only.
Can anybody offer advice on how to figure out what's wrong and what to replace. Could the fuses be bad even though they look ok? Thank you
i would not do that to tweeters, but woofers are just fine with that.
Nah, any decent compression driver will be fine, though I only use 3V on domestic tweeters.
The woofers as several have already said, are totally re-basketable. You don't have to send them to anyone to get it done. Takes all of 5 min to replace one. If there are any power resistors in the crossover I would check those. They can open up or change resistance when driven really hard.
Forgive me if you've already done this, but have you verified that the electronics work with another set of speakers? It's not clear that you have from your troubleshooting description. You don't need anything with PA durability, just turn it down and hook up any set of speakers and verify that decent quality sound is being fed to the speakers. Hafler DH500's have a speaker fusing arrangement that allows a very thin sound through if blown...
I use Al's battery trick, albeit with a AA battery. Try it from cabinet input connector. I've seen bad jacks allow plugs to be blown out with slap bass. If the 1/4" jack turns out to be the problem you might consider modifying the cabinet with Speak-Ons.
If you can't get a sound from the input then move to the drivers as Al suggested. If the drivers are OK, then there's an issue between input and driver. Try the battery at the crossover input. If that works, it's most likely a bad jack. If not, your fuses may have gone slowly and just look OK.
You just need to step through the system methodically to find the bad part. Good luck.
Great, thanks for all of the input! I've got some more things to try out! I will try the 9V test now. To respond to BobEllis, I have used my electronics through other speakers and the setup sounded great. The slow fuse burnout could be it. I pushed these speakers to their limits while they worked- i'll say that. They also got a good bit of traveling, in and out of a humid van and all around the country in summer and in winter...
- Live Sound
- PA Systems
- NO SOUND on PA mains please help
