Some hints for a 1kW PA - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 28th January 2011, 01:02 AM   #11
CBS240 is offline CBS240  United States
CBS240's Avatar
With that kind of power and current consumption, perhaps a class D amp working in class G operation to form an envelope to a linear amp would be the most efficient way to produce a low distortion arc welder, er, rather 1KW @ 2R. It just seems like a lot of extra heat to waste in using a totally linear amp for 1KW output power.
All the trouble I've ever been in started out as fun......
Old 28th January 2011, 06:04 AM   #12
effebi is offline effebi  Italy
effebi's Avatar
I agree completely. Unfortunately I never did a class D stuff. I will study that, I hope it should not be too different from some PWM drive.
Do you really belive that it is possible to reach 0.1 % THD that way? At a first look a class H seems to me more reassuring.
Thank you.
effebi
Old 28th January 2011, 08:38 AM   #13
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
CBS240 offering classG with classD as envelope and the amplifier is linear.
Like this:
Its only need +50V for +/-45V outputs.
The Composite / Hybrid- Linear + Switching Power Amplifier
Isn't it better to use 2x500W? or at least start with lower power first.
Old 28th January 2011, 08:46 AM   #14
effebi's Avatar
Like this:
The links you posted are very interesting.
What you mean 2 x 500 W? bridge? Parallel?
A i said, I do need 1kW on 2R, 65-0-65 rails.
I am not afraid about hi-power, in other fields i was designing multi kW devices.
Old 28th January 2011, 07:53 PM   #15
Federmann's Avatar
Send a message via ICQ to Federmann Send a message via Skype™ to Federmann
Preamp with limiter schematic, need some hints petrol vendor Instruments and Amps 0 15th August 2008 05:48 PM
Class-d for a 1kw PA amp MikeHunt79 Class D 4 30th December 2007 06:19 PM
Hints for starting a KG amp. Garbz Solid State 3 14th March 2004 10:31 AM
Scott Joplin: need hints! dice45 Music 12 19th August 2002 01:36 PM
Copyright 1999-2017 diyAudio
