Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 4th December 2010, 04:13 AM   #1
Antonio Tucci's Avatar
Default Tube mixer
I'm projecting a 10 Ch mixer tube, with an IC output section for 4 monitors (...where a high quality of the signalit is not necessary).
1) I'd like to know if the outputs IC sections (for the monitors) may affect the signal after the tone control section.
2) Somebody can help to answer to the questions reported into the IC section?
Many anticipated thanks
Old 4th December 2010, 04:25 AM   #2
Default ... a better image of the schematic
Sorry ... I enclosed a better image of the schematic.
Old 4th December 2010, 10:01 AM   #3
ruffrecords's Avatar
Hi Antonio,
I think the first thing you need to look at is the tone control stage because I think with the values shown it will present too heavy a load to the tube stage driving it. This will cause much more distortion than any loading effects the later IC stage might cause.
Cheers
Ian
Ian
Old 4th December 2010, 11:48 AM   #4
SY's Avatar
The White cathode follower should be able to deal with the tone controls. My question is, why so much gain? The way you have it set up, gain is about 250. That seems... excessive. The input cap for the tone controls is not necessary if the preamps have output capacitors. The internal coupling caps can be 2-10uF. R1 can be large- 100k will work fine (not critical). R5 can be 10k (not critical). R4 is superfluous.
If there's a sucker born every minute, where do the rest of them come from?
Old 4th December 2010, 05:59 PM   #5
I see no White follower, just a regular CF with a CC load. Either way, the tone controls with the values shown will look like a 2K load at mid frequencies which will definitely lead to increased distortion.
Cheers
Ian
Ian
Old 4th December 2010, 06:54 PM   #6
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I don't use tone controls in my tube mixer: today tube mixers are too expensive to be used with crappy dynamic mikes that need individual equalization.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 4th December 2010, 07:29 PM   #7
But, of course, that is NOT what EQ is for.
Cheers
Ian
Ian
Old 4th December 2010, 07:32 PM   #8
Wavebourn's Avatar
Can you enlighten me please, what for are Baxandall shelf-type EQs in each channel strip then?
Old 4th December 2010, 09:04 PM   #9
Well a Baxandall HF/LF EQ is clearly quite simple and therefore limited but it does have its uses.
Often when mixing, it is important to manage the audio spectrum. In particular, to avoid muddying the bass (guitar or synth etc) it is common practice to roll off the bass end of all other instruments (guitars, snare drums etc). In other cases bass roll off is used to achieve a particular sound e.g to make a thin sounding rythm guitar.
Equally, to add sparkle, it is common to add some HF boost to individual instruments.
Cheers
Ian
Ian
Old 4th December 2010, 09:18 PM   #10
Wavebourn's Avatar
All instrumental amps have own tone controls, so even when miking cabs I don't see any reason to have Baxandall controls in channel strips. I've found that the better are mikes and mike preamps, the less audio engineers want any EQ in them. Do you read Gearslutz forum, Ian?
Insert sockets would be much more valuable, according to my experience.
Tube based mic preamp mixer amperex Instruments and Amps 7 22nd February 2006 09:06 PM
Tube mic preamp/mixer Sir Trefor Tubes / Valves 31 21st November 2004 09:52 PM
Tube mixer design rafafredd Tubes / Valves 2 6th February 2003 01:23 PM
Building 8x2 tube line mixer rafafredd Tubes / Valves 1 26th December 2002 06:35 AM
Copyright ©1999-2013 diyAudio
