Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 4th December 2011, 08:46 PM   #41
Saturnus's Avatar
Originally Posted by sakis View Post
( Cause if its class H,G, T or D i dont think that it can be compaired in quality even with the most simple amplifier that is presented in the forum and that will be the DX amplifier from destroyer X )
Oh really? A class D can't be a pro or a hi-end amp?
Old 6th December 2011, 08:03 PM   #42
This amp is a "marriage" between Class A and class D and it has got some excellent reviews
I have read one of them in the Norwegian magazine Fidelity. It´s not a pro amp but might point in one direction that will be followed by others. BTW it´s not the first attempt to combine Class A with D .
6moons audio reviews: A mini review of the Devialet D-Premier
Recommended Reference Component: Devialet D-Premier Integrated Amplifier-DAC
Without wonderment,no life.
Old 6th December 2011, 08:11 PM   #43
I have a pair of 1960's Webster TP12-1 PA amplifiers (6V6 PP).
I converted them into pair of mono blocks last year.
They still need some additional work, as one has a greater volume level than the other?
It is not a big deal to just adjust one volume control up or down.
But being a blatant 'perfectionist', the volume difference bothers me.
Steve
Old 8th February 2012, 03:00 PM   #44
The DAP Audio DPA-2400 looks interesting. Lightweight and compact due to a ( probable) SMPS. Marketed as Hexfet class D. But why call it "Vintage" ?
DPA-2400 Vintage - Ljudia - Multimedia Hemelektronik Karaoke PA anläggning DJ utrustning Ljus utrustning
Old 10th February 2012, 10:38 PM   #45
4642a is offline 4642a  United States
those CS800s are real close to some BGW amp circuits, IIRC....
i am using a pair QSC MX3000a for subbass in my basement....
Old 10th February 2012, 11:32 PM   #46
nigelwright7557's Avatar
I use a class d 750 watt amplifier in my living room.
I run it into a 18 inch bass cab and a 4 by 10 inch full range cab.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 10th February 2012, 11:55 PM   #47
I had a pair of Crown CE4000 for the subs but sold them when I was in danger of losing the house.
Now I have a stack of older fan-cooled professional amps, with SMPS and FET outputs (surprising for their age). They have balanced inputs and plenty of power. And they sound GREAT IMHO.
I used to have a pair of Peavey DECA 1200 amps, which were class D. They sounded pretty good for bass and mids (which was where I used them).
Old 11th February 2012, 12:09 AM   #48
I have, in the past. Generally speaking they worked well but just not quite as good as a home HiFi amp fidelity-wise. Certainly if you need the power they can be an economical choice; I wouldn't say any of them sounded "bad". It's just that I found that the differing priorities in Pro Sound and HiFi revealed themselves in the sound.
I wouldn't use home gear for Sound Reinforcement either; in fact I would say it's probably worse to go the other way. Although I did see Ravi Shankar live (in a concert hall, though) playing his sitar through an array of Quad ESLs (the original ones). Have to admit it sounded amazing, but that was many years ago.
If you're too young to know Ravi, you might know his daughter ... some girl by the name of Norah Jones.
Some amps can do double duty but then again those examples are not that economical.
" ... Go back to the beginning of a technology before the priesthood was established; that was the time when people were communicating information, not proving why there needs to be Priests. This is why the old texts tend to be so good. ..."
Old 25th March 2012, 05:10 AM   #49
prasanna gunasinhe's Avatar
I use QSC GX5 with Yamaha 12 CH mixer excellent sonic performance!!
Old 25th March 2012, 05:38 AM   #50
Just got another Crown Comtech 400 installed in my living room and it drives a pair of JBL HLS 810's and a Paradigm sub very well. I tried the Comtech 400 on 2 different sets of speakers and the speakers are definitely the main limiting factor.
While amplifiers are important in the production of sound, the part with the room for the most improvement is the speaker setup.
Should I build a home subwoofer system with two 15" MTX Black Golds (car subs)? dan50 Subwoofers 1 13th September 2007 02:47 AM
Home sub with PA driver Khron Subwoofers 6 15th August 2006 10:21 AM
pa mids for multi car/home use lynchingacers Full Range 4 27th June 2005 02:48 AM
car or PA or home theatre drivers Kilowatt Multi-Way 12 1st May 2002 04:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 20.00%)
Copyright ©1999-2013 diyAudio
