DIY PA Speakers Setup (Line Array) - Page 4 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 25th May 2011, 07:43 AM   #31
apexaudio's Avatar
Simple 12inch two way speaker box, can be use with 18inch sub.
Old 25th May 2011, 02:41 PM   #32
apexaudio's Avatar
Very low cost, and easy for diy.
Old 25th May 2011, 04:38 PM   #33
mihailo is offline mihailo  Serbia
Very nice speaker project.
What is the diameter of holes for air circulation? How deep must be tubes?
Can you please post some tweeter protection or crossover?
Thanks.
Old 25th May 2011, 08:09 PM   #34
apexaudio's Avatar
Thanks.
Thats all depend of uses driver...
Old 26th May 2011, 10:29 AM   #35
Drivers are:
1. Ei nis AZ1201 80W/8ohm 45-6000Hz
2. Eminence Delta 12 LF 500W/8ohm 44-3000Hz
3. RTO horn 50W/8ohm 2000-21000Hz
Old 26th May 2011, 10:35 AM   #36
I am currently using Eminence 12LF in some subs, but I would hear them also in 2 way box, so can you now tell me what diameter for tube and how long should I use in your project? For Ei and Eminence.
Old 26th May 2011, 11:04 AM   #37
If you do not mind Apex , would like to add plans for 12" sub that I am using.
It is not difficult to build, and bass is very powerful.
Old 26th May 2011, 11:07 AM   #38
I had shanged original design a little bit...
Old 27th May 2011, 04:36 AM   #39
sir apex,
a little bit off topic,
can you please share something about h900 issues by gitsa
how to fix his problem,
and please share your waveform
Old 27th May 2011, 05:51 AM   #40
A square's Avatar
Send a message via Yahoo to A square
nice sub sir....
jon
DIY Line Array for Pa system - Driver Selection woodrowman Full Range 9 12th October 2016 04:14 PM
cheap DIY PA speakers for garage/shop? khaosman Multi-Way 6 12th September 2011 01:23 AM
PA Speakers DIY MrMagnus PA Systems 25 21st August 2010 01:37 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 07:54 PM
Got my line array speakers and did a quick test setup mazeroth Multi-Way 12 24th August 2004 03:43 PM
Copyright 1999-2017 diyAudio
