PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
DIY PA Speakers Setup (Line Array)
Old 26th August 2013, 02:09 AM   #131
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default HF X-OVER + PROTECT
Hi Apexaudio
greetings i have assembled your HF -X OVER as shown in post #61
hf response is very clear compression driver i am using is P AUDIO BM450 CAN you give turns of .2mh air core inductor
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 30th August 2013, 07:41 AM   #132
SIDEWINDER 18X is offline SIDEWINDER 18X  India
SIDEWINDER 18X's Avatar
Originally Posted by andrewlebon View Post
Hi Apexaudio
warm regards
andrew lebon
Hi Andrew,
Can you post me the schematic diagram of your HF - X OVER as in post #61.
I can give you turn details and all info on winding 0.2mh (200uH) air core inductor. Provided, if you let me know .....
1. Do you have a plastic bobbin to wind the coil ?. If yes.
2. What is the bobbin size ????? . I mean, bobbin internal height & inside diameter.
Old 30th August 2013, 12:49 PM   #133
If you do not have any specific x-over bobbins, you can use any circular plastic bobbins. eg: empty solder spool bobbins or medi-plast bobbins etc
Just measure the size of it's internal diameter & inside height and post me.
And also the wattage or power you want through it.
I shall tell you the turns details, DCR, and wire gauge in SWG.
Old 24th September 2013, 09:37 AM   #134
DAMANHURI is offline DAMANHURI  Indonesia
DAMANHURI's Avatar
Hi Apex (mr. Mile) can u share Box Speaker subwoofer 10'' for Home Audio. I want to try to make karaoke in my room.
Best regards - Damanhuri
Old 10th November 2013, 06:52 AM   #135
sandman15th is offline sandman15th  Philippines
sandman15th's Avatar
sir miles if i reverse the position same like on the photo of your horn reflex bass box design,what is the difference or affect?? thanks by the way that design is mtl dual sub.almost same to your sub..(not sure) i dnt have the plan of this box ..
Old 10th November 2013, 01:40 PM   #136
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Averange angle of this subs is 90x40deg so vertical position is wrong.
Old 14th November 2013, 03:01 PM   #137
apexaudio's Avatar
MB10-SUB
Old 15th November 2013, 01:03 PM   #138
apexaudio's Avatar
MB-Sub plans
Old 21st November 2013, 10:05 PM   #139
apexaudio's Avatar
Full-range speakerbox idea.
2x12" in band-pass for bass, 2x8" for mid and HF...
Old 22nd November 2013, 01:17 PM   #140
QQ12e5k1 is offline QQ12e5k1
Default 10 inch sat
Dear Mile,can You share the detail at post 89?
DIY PA Speakers Setup (Line Array)Hide this!Advertise here!
DIY Line Array for Pa system - Driver Selection woodrowman Full Range 9 12th October 2016 04:14 PM
cheap DIY PA speakers for garage/shop? khaosman Multi-Way 6 12th September 2011 01:23 AM
PA Speakers DIY MrMagnus PA Systems 25 21st August 2010 01:37 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 07:54 PM
Got my line array speakers and did a quick test setup mazeroth Multi-Way 12 24th August 2004 03:43 PM
