PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
DIY PA Speakers Setup (Line Array)
Old 25th March 2013, 01:32 AM   #111
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Symmetrical Scoop idea
Old 25th March 2013, 10:18 AM   #112
apexaudio's Avatar
Advantage of folded horn is that the floor extended horn length.
Old 25th March 2013, 10:43 AM   #113
apexaudio's Avatar
Another version of symmetrical scoop.
Old 26th March 2013, 01:06 PM   #114
wattaniya is offline wattaniya
hi apex sir,
this is ur 18inch sub design. 500w each.
is it need crossover for this sub, pls give a crossover sch.
Old 26th March 2013, 02:04 PM   #115
apexaudio's Avatar
Originally Posted by nazirdigi View Post
hi apex sir,
Nice work, use x-over from posts #1o2 and #104 in thread:
http://www.diyaudio.com/forums/analo...reamps-11.html
Old 26th March 2013, 03:02 PM   #116
thank u apex sir for the reply
Old 26th March 2013, 08:34 PM   #117
apexaudio's Avatar
Folded Horn idea for 15inch driver
Old 5th April 2013, 09:15 AM   #118
hi apex sir,
i found one problem with 18 inch sub,
the sound is good without the plastic bottom corners(dirrectly keep the box in the floor),but when i fix the plastic four corners to the box and checked the sound , the sound is not hard, any solution?
Old 5th April 2013, 10:05 AM   #119
apexaudio's Avatar
hi apex sir,
There can't be any audable difference with plastic corners, check phase of drivers.
Old 5th April 2013, 11:50 AM   #120
the drivers are same phase and the distance also same.
if i keep one feet distance from the floor the hardness is not good,but if i keep in the floor very good .
what will be the problem?
DIY PA Speakers Setup (Line Array)Hide this!Advertise here!
DIY Line Array for Pa system - Driver Selection woodrowman Full Range 9 12th October 2016 04:14 PM
cheap DIY PA speakers for garage/shop? khaosman Multi-Way 6 12th September 2011 01:23 AM
PA Speakers DIY MrMagnus PA Systems 25 21st August 2010 01:37 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 07:54 PM
Got my line array speakers and did a quick test setup mazeroth Multi-Way 12 24th August 2004 03:43 PM
