DIY PA Speakers Setup (Line Aray) - Page 9 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 4th June 2012, 11:25 PM   #81
apexaudio's Avatar
Bass 2x12inch + mid 4x6inch + 2inch HF driver
File Type: jpg 462833_368411359889305_217903845_o.jpg (505.7 KB, 1544 views)
Old 5th June 2012, 11:31 PM   #82
irwanks is offline irwanks  Indonesia
Originally Posted by apexaudio View Post
This is overcurrent protect for HF driver, can be set with change 0,47R.
hello sir, can you help me? In facebook you said that "‎2,5A peak current limit is 25W RMS for 8R driver, about 300W on x-over input" How to calculate it? Can you teach me? If I change 0,47R to 0,56R What will happen? Thank you very much.
Old 6th June 2012, 01:10 PM   #83
adamkaktus's Avatar
Default 15"horn enclosure
Hello, i found here some 2x12", 2x15" 2x18" and 1x12", 1x18" enclosures, but i did't found any for 1x15" horn/BP enclosure, can You share some of them mr Apex? I'm interested in building two small, but effective subs based on 15tbx100 or 15nw100 or similar from B&C.
PS, i think in 4 ohm option of this speakers they would work well with your H900 based power amp.
Old 6th June 2012, 02:55 PM   #84
apexaudio's Avatar
B151
File Type: jpg 469202_10150699785439093_160028135_o.jpg (153.6 KB, 1341 views)
Old 6th June 2012, 03:02 PM   #85
apexaudio's Avatar
Sat pictures
File Type: jpg 319778_369364526460655_2041705031_n.jpg (86.8 KB, 1231 views)
File Type: jpg 484386_369361493127625_1336483431_n.jpg (127.2 KB, 1164 views)
File Type: jpg 550607_369364033127371_1294335469_n.jpg (89.1 KB, 1108 views)
File Type: jpg 560188_369360603127714_1709857105_n.jpg (130.3 KB, 531 views)
File Type: jpg 598478_369362193127555_436354512_n.jpg (156.8 KB, 632 views)
Old 6th June 2012, 03:29 PM   #86
adamkaktus's Avatar
THX mr Apex can you translate notes on picture for english? Serbian istn't so easy even for polish people
Old 7th June 2012, 03:06 PM   #87
Give some advice to this people
and what about this its mine sound system
Old 14th June 2012, 10:05 AM   #88
2lok is offline 2lok  South Africa
Hi Apex,
Out of curiosity:
For you B2181 Horn Reflex design,
What is your projected or measure Continuous and Max Spl?
Resonant Frequency of the cab design itself?
What drivers have you installed into this design?
Thanks!
Old 24th June 2012, 10:21 PM   #89
apexaudio's Avatar
Simple 10 inch sat
Old 25th June 2012, 07:24 AM   #90
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Hello. Did you make the box that this speaker is standing on yourself also? I am interested in what the carpet like coating material is called and where it can typically be obtained. I've had no luck searching for it on google.
Regards, James
DIY Line Array for Pa system - Driver Selection woodrowman Full Range 7 24th November 2013 01:49 PM
cheap DIY PA speakers for garage/shop? khaosman Multi-Way 6 12th September 2011 02:23 AM
PA Speakers DIY MrMagnus PA Systems 25 21st August 2010 02:37 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 08:54 PM
Got my line array speakers and did a quick test setup mazeroth Multi-Way 12 24th August 2004 04:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
