Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 13th January 2012, 10:47 AM   #71
Originally Posted by apexaudio View Post
This x-over is for 1 inch HF driver use with 500W amp
what changes do i have to make for this x-over to work with h900
Old 17th January 2012, 12:00 PM   #72
apexaudio's Avatar
This is overcurrent protect for HF driver, can be set with change 0,47R.
Old 17th January 2012, 02:27 PM   #73
apexaudio's Avatar
This protect don't compress peaks.
File Type: jpg APEX HF X-OVER + BJT PROTECT not compress peaks.jpg (139.5 KB, 285 views)
Old 17th January 2012, 05:59 PM   #74
wg_ski is offline wg_ski  United States
It just clips them. Won't that 10 watt resistor go smoke if you run the thing continuously in protect? DJs have been known to do that. I'd beef it up to a pair of 20 watters in parallel - and don't forget to heat sink the power transistor.
Old 17th January 2012, 07:28 PM   #75
apexaudio's Avatar
Yes resistor must be 40W if power is continuously double than maximum (25V RMS on driver), I forget protect from DJs
Old 18th January 2012, 06:02 PM   #76
apexaudio's Avatar
Protect with MOSFET instead BJT.
File Type: jpg APEX HF X-OVER + MOSFET PROTECT not compress peaks.jpg (122.3 KB, 264 views)
Old 9th February 2012, 05:20 PM   #77
apexaudio's Avatar
3D
Old 10th February 2012, 03:38 AM   #78
Apex sir,
about 3D
please share some more details.
Old 10th February 2012, 09:38 AM   #79
apexaudio's Avatar
Originally Posted by sudhir kumar View Post
Apex sir,
about 3D
Details in post #22
Old 24th May 2012, 11:14 AM   #80
Sir Apex,
Can we cover open front of the box shown in post #77 with some metal gril or mesh ? does this will effect the performance ?
cheap DIY PA speakers for garage/shop? khaosman Multi-Way 6 12th September 2011 01:23 AM
PA Speakers DIY MrMagnus PA Systems 25 21st August 2010 01:37 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 07:54 PM
DIY Line Array for Pa system - Driver Selection woodrowman Full Range 1 20th May 2008 10:58 PM
Got my line array speakers and did a quick test setup mazeroth Multi-Way 12 24th August 2004 03:43 PM
Page generated in 0.09964 seconds (68.42% PHP - 31.58% MySQL) with 11 queries
