DIY PA Speakers Setup (Line Aray) - Page 7 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 26th December 2011, 09:21 PM   #61
apexaudio's Avatar
Default HF X-OVER + PROTECT
X-over circuit with fast mosfet protect for horn drivers.
Old 9th January 2012, 01:04 AM   #62
andrewlebon's Avatar
Default HF PROTECT
Hi Apexaudio
new year greetings can your protect be used for 100 watt hf
compression drivers amplifier output per channel is 2000 watts nice project
please can you explain how circuit works
warm regards
andrew lebon
Old 10th January 2012, 05:38 AM   #63
Default hf protect
Dear Sir
hello please will this circuit protect my hf please help me and tell if my pcb wrong
thanking you
sameerx1
Old 10th January 2012, 09:06 AM   #64
apexaudio's Avatar
Originally Posted by sameer x1 View Post
Dear Sir
thanking you
sameerx1
Pcb is OK, use heatsinks for IRFs and increase value of 2k2 resistor to 2k7 or 3k3 for smal HF drivers.
Old 10th January 2012, 12:17 PM   #65
Default speaker setup for karaoke
Dear Mile,
Can You help me to make setup speaker for karaoke for little room about 6x8 m???
I mean box construction for 2.1 channel and what type of your amps to drive it??
Old 12th January 2012, 05:53 PM   #66
apexaudio's Avatar
Simple HF x-over with halogen lamp protect.
Old 12th January 2012, 09:10 PM   #67
mile,
how many watts this x-over limiter can handle
post#66
Old 12th January 2012, 09:13 PM   #68
and this x-over,
will this work w/o changes with h900 amp
Old 12th January 2012, 09:24 PM   #69
apexaudio's Avatar
Originally Posted by engel dela pena View Post
mile,
post#66
1200W, but with 2 inch HF driver
Old 12th January 2012, 09:27 PM   #70
apexaudio's Avatar
and this x-over,
This x-over is for 1 inch HF driver use with 500W amp
DIY Line Array for Pa system - Driver Selection woodrowman Full Range 7 24th November 2013 12:49 PM
cheap DIY PA speakers for garage/shop? khaosman Multi-Way 6 12th September 2011 01:23 AM
PA Speakers DIY MrMagnus PA Systems 25 21st August 2010 01:37 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 07:54 PM
Got my line array speakers and did a quick test setup mazeroth Multi-Way 12 24th August 2004 03:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
