DIY PA Speakers Setup (Line Aray) - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 22nd September 2010, 12:41 AM   #11
imix500 is offline imix500  United States
imix500's Avatar
Well, they are W-Bins. Don't get me wrong, I've had a lot of fun with them, but you often need quite a few to get the job done.
For the line array, keep in mind that you cant use just any CD horn. It must be very carefully chosen to work well with adjacent boxes. Some use multi-varying length throats to focus the energy, some use several drivers with rib-like structures built in front of the drivers to do the same. There are several designs in use out there, but those are the ones I work with day to day.
Old 22nd September 2010, 12:42 AM   #12
Banned
Originally Posted by apexaudio View Post
You don't need 'em, but people who put 40 subs and 10 two way suts over need some advice and suggestions
Just take a few minutes and model your ideas in Mr McBean's Horn Response program. It's pretty darn accurate Hornresp
Old 22nd September 2010, 12:56 AM   #13
apexaudio's Avatar
CD horns for line array is available, but it's still bigest problem. I not suggest W-Bins, I suggest horn reflex like EV phenix PX2181 or old MTL1X.
Old 22nd September 2010, 01:03 AM   #14
imix500's Avatar
Indeed. The old MTL subs are still well respected, even if no one likes lifting them.
Old 22nd September 2010, 01:06 AM   #15
apexaudio's Avatar
I use similar horn like KV2 in EX1, modeling not meatching with real life.
Old 22nd September 2010, 01:13 AM   #16
apexaudio's Avatar
I suggest sub with more compact size than usual for two 18inch speakers.
Old 22nd September 2010, 01:24 AM   #17
apexaudio's Avatar
Front panel (500x500mm) with mids and CD horn can be rotate 90deg angle, if use one box in setup.
Old 22nd September 2010, 01:45 AM   #18
Banned
What does meathing mean? Do you mean when you model the KV2 it does not perform like the Horn Response model? Are you using it and modeling it in half space?
Old 22nd September 2010, 01:52 AM   #19
Speakerholic
Cal Weldon's Avatar
I think it means matching.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 22nd September 2010, 11:38 AM   #20
apexaudio's Avatar
I'm sorry for my bad English
DIY Line Array for Pa system - Driver Selection woodrowman Full Range 7 24th November 2013 12:49 PM
cheap DIY PA speakers for garage/shop? khaosman Multi-Way 6 12th September 2011 01:23 AM
PA Speakers DIY MrMagnus PA Systems 25 21st August 2010 01:37 PM
5.1 DIY kit with on PA speakers (or good & small DIY kit with PA speakers) ? jm_kzo Multi-Way 54 22nd April 2009 07:54 PM
Got my line array speakers and did a quick test setup mazeroth Multi-Way 12 24th August 2004 03:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
