PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Need to quiet down old mixer w/LM301s
Old 11th June 2010, 05:35 PM   #21
Th3 uN1Qu3 is offline Th3 uN1Qu3  Romania
Send a message via Yahoo to Th3 uN1Qu3
Originally Posted by jean-paul View Post
That is not entirely true as a new mixer will have mediocre opamps too.
Just don't expect real good opamps in mixers.
Well i don't need "real good opamps", the ones it has inside sound just fine as far as music is concerned. I just want less hissing on the mike inputs.
Old 11th June 2010, 05:37 PM   #22
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Just as I said: you need real good opamps ( which will hiss less than the current ones). Also metalfilm resistors are recommended.
Although it's an interesting project ( at least for educational purposes) I would only start when I would have a good use for the mixer.
It's only audio. Member of the non modular PCB design committee
Old 11th June 2010, 05:38 PM   #23
Maybe i just need better mikes, ones that don't need the trim turned all the way up. I'll inspect that later on... First thing first, i'll get all channels working and add phantom power. This should greatly expand my selection of mikes.
Old 21st December 2017, 01:03 PM   #24
Shelah is offline Shelah  Zambia
is there a recent replacement for k157ud2 opamp, i have an old eq that uses them
Old 21st December 2017, 08:17 PM   #25
GeorgK is offline GeorgK  Austria
This is a russian type, right?
If you cannot find an exact replacement you could make a small adapter board and use a standard dual OPV. You probably also omit the compensation caps then (if used).
Need to quiet down old mixer w/LM301sHide this!Advertise here!
Chipamp is too quiet. raypalmer Chip Amps 6 30th January 2009 11:55 AM
How quiet is dead quiet? pchw Tubes / Valves 36 22nd November 2007 04:36 AM
Quiet here, isn't it? pinkmouse The Lounge 24 8th February 2005 08:29 PM
How quiet will it be? MMicke Chip Amps 8 12th July 2003 08:26 PM
Too quiet! grataku Everything Else 14 14th February 2003 04:39 PM
