Inside a "no brand" PA Amp... - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 29th May 2010, 09:13 PM   #11
nigelwright7557's Avatar
It looks very much like the inside of cheap amp I bought off ebay.
I was shocked at the minmal heatsink and transformer for the wattage specified for the amp.
The amp worked but definitely did not give the wattage advertised.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 29th May 2010, 09:18 PM   #12
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Originally Posted by Arnulf View Post
I'm curious though, how does 2x16V transformer provide enough voltage for +/- 35V rails using a simple rectifier bridge ?
OP says 2x26v... 26 x 1.414 = 36.7vdc
AJ
Old 29th May 2010, 09:43 PM   #13
Arnulf is offline Arnulf  Europe
Oh, I'm sorry, I honestly misread that as 16V That makes sense now.
mod verb, transitive /mod/ to state that one is utterly clueless about the operation of device to be "modded" and into "fixing" things that are not broken; "My new amplifier sounds great so I want to mod it."
Old 30th May 2010, 07:19 AM   #14
svokke is offline svokke  Belgium
Well, the "mosfets" look exactly like the KSA940, a PNP transistor. I wonder why they would use an all PNP output stage. Looks like a design from the late 1950's. Also there is no temperature compensation at all, so it is possible that these amps self-destruct by thermal runaway.
I'll probably scrap the Amp PCB. It's no good at all.
In illusion comfort lies
Old 30th May 2010, 07:31 AM   #15
h_a is offline h_a  Europe
h_a's Avatar
I can't imagine how a mosfet amp without manual bias adjustment should work in any reasonable way. VGS is usually all over the map. Matching is too expensive for cheap amps, anyway. VBE of bipolars is perfect in comparison.
Have fun, Hannes
Old 30th May 2010, 07:54 AM   #16
Nrik is offline Nrik  Denmark
Hmm - where does the bases/gates (most left pin) of the lower and the upper outputs go exactly? ( you have drawn them differently in your schematics so it is hard to gues) Double check that so that we can conclude what type it is.
Hereafter 2 options:
1) Replace all outputs with cheap new ones, and add a proper bias circuit.
2) Replace the PCB with DXamp or Symasym, and mount a decent heatsink.
Henrik
Old 30th May 2010, 08:17 AM   #17
HighTec is offline HighTec  Croatia
HighTec's Avatar
Hm, that D2, 1N4148 should be mounted or at least touching the heatsink to ensure some thermal tracking. Anyways, like you said, that piece of junk isn't worth repairing. Replace it with some reliable design.
Old 30th May 2010, 10:04 AM   #18
Globulator's Avatar
So at full load that would probably give a rail of 26V then, RMS power = 26x26/(8x2) = 42.25W
If someone blew the transistors at that power they were probably fakes. I'd advise using the box for a nice DIY pre-amp, can't see any mileage in that amp..
Old 30th May 2010, 12:25 PM   #19
I just noticed the value of R7 - 33ohms - this is a pure class B design!
Svokke : If you want good sound you should skip the original pcb, and put in another amplifier.
Henrik
Old 30th May 2010, 01:03 PM   #20
gruni is offline gruni  Germany
almost the same amp design can be found in those "hollywood" or "skytec" or "nightline" or whatever amps you can get off ebay here in germany. they are also rated 480 watts (although there is an even cheaper model rated 240 watts, which has only two output transistors per channel)... i have the schematic diagram of these amps somewhere, perhaps i'll find it, so i can upload it here.
"transformers" inside car amp?? Dan2 Car Audio 23 3rd June 2008 12:25 AM
Speaker "QUIZ" name brand&Type 4590 Multi-Way 9 6th January 2006 12:45 PM
Anyone heard of "Blues" brand speakers from early 1990's? beady Multi-Way 2 4th August 2004 08:08 PM
Does anyone know the brand "QED" for cables & interconnects? Bricolo Parts 7 25th June 2003 09:32 AM
Copyright 1999-2017 diyAudio
