PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Inside a "no brand" PA Amp...
Old 30th May 2010, 01:35 PM   #21
jaycee is offline jaycee  United Kingdom
For 70 that is a cheap 2U, transformer and heatsink. Could put a nice 40W per channel amp in it, although 120VA might be a bit small.
Old 30th May 2010, 01:42 PM   #22
infinia is offline infinia  United States
infinia's Avatar
Originally Posted by Nrik View Post
I just noticed the value of R7 - 33ohms - this is a pure class B design!
Svokke : If you want good sound you should skip the original pcb, and put in another amplifier.
D2 is mostly a three diode assy? and s/b mounted to the output heatsink as well the drivers. If it isn't , then you need to keep the heat rise down, by low bias current and a big HS or Fan.
Old 30th May 2010, 08:33 PM   #23
svokke is offline svokke  Belgium
almost the same amp design can be found in those "hollywood" or "skytec" or "nightline" or whatever amps you can get off ebay here in germany. they are also rated 480 watts (although there is an even cheaper model rated 240 watts, which has only two output transistors per channel)... i have the schematic diagram of these amps somewhere, perhaps i'll find it, so i can upload it here.
I am very interested in this schematic. The amplifier I have looks exactly the same as a skytec PA-240, only difference is the name tag in the center of my front panel ("IBIZA"). This way we would finally know what are the output devices.
In illusion comfort lies
Old 31st May 2010, 07:53 PM   #24
Someone7272 is offline Someone7272  United Kingdom
Can we see the front face of the amp please? It looks very much like my Skytronic amp. Except mine's rated at 600W and weighs quite a bit.
Old 1st June 2010, 12:25 AM   #25
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I tend to use low bias on my amps so I dont need any thermal feedback.
I apply a sine wave and monitor the output across the speaker.
I turn up the bias until crossover distortion just goes.
Usually sounds pretty good.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 1st June 2010, 09:51 AM   #26
R.I.P.
following up on Jaycee's advice.
The easiest way to save most of your investment is to throw away the amplifier PCB and substitute one or two chipamps.
With the 26Vac transformer a 3886 can put out a maximum of ~60W into 8r0.
You could not use it for 6ohm or 4ohm speakers.
regards Andrew T.
Old 1st June 2010, 11:04 AM   #27
Globulator is offline Globulator  United Kingdom
Globulator's Avatar
Or a nice Tripath amp.
In fact with a tube pre-amp PCB and a tripath main amp PCB it could be really nice. Most other things will be more expensive and poorer sounding.
Old 3rd June 2010, 04:07 PM   #28
Today I took one of the transistors apart. I think this looks like a bipolar. So it really could be the 2SA940 or KSA940, both PNP devices. Is this die about the correct shape and size for those transistors?
Old 3rd June 2010, 04:34 PM   #29
Nrik is offline Nrik  Denmark
It would be easier to track exactly where the most-left-pin goes. That would give away the type.
Henrik
Old 3rd June 2010, 06:15 PM   #30
The most left pin of Q6 goes to the middle pin of Q1(=collector) in your picture. I have re-drawn the schematic.
Inside a "no brand" PA Amp...Hide this!Advertise here!
"transformers" inside car amp?? Dan2 Car Audio 23 3rd June 2008 12:25 AM
Speaker "QUIZ" name brand&Type 4590 Multi-Way 9 6th January 2006 12:45 PM
Anyone heard of "Blues" brand speakers from early 1990's? beady Multi-Way 2 4th August 2004 08:08 PM
Does anyone know the brand "QED" for cables & interconnects? Bricolo Parts 7 25th June 2003 09:32 AM
