Mic, Line, EQ... Preamps - Page 35 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 19th July 2012, 08:11 AM   #341
apexaudio's Avatar
Originally Posted by joexswj View Post
my preamp ML3 with standar part in lokal state
Nice work
Old 20th July 2012, 07:09 AM   #342
joexswj is offline joexswj  Indonesia
joexswj's Avatar
thanks Mr.Mile , i can learn to DIY project
Old 7th August 2012, 03:09 AM   #343
joexswj's Avatar
ML3 with gain, unbalance input...
Old 13th August 2012, 04:41 AM   #344
de Ocampo's Avatar
Sir Mile,
My mains power transformer had a +/-18vac secondary winding. I would like to use it for this preamp psu design, will it maintain the +/-15vdc regulated output supply?
Can I also use TIP41C for the power regulators? and any other substitute for the TO-92 fets?
Thanks!
Old 13th August 2012, 08:09 AM   #345
apexaudio's Avatar
Originally Posted by abeteer View Post
Sir Mile,
Thanks!
Use 2x18vac, TIP41C/TIP42C and 2SK246 FET,
Old 14th August 2012, 04:31 AM   #346
de Ocampo's Avatar
OK, thank you Sir.
Old 25th August 2012, 11:05 PM   #347
de Ocampo's Avatar
Sir Mile,
Do you still have the foil pattern for toner transfer on this fan control circuit? I tried to do it manually using pen type cutter over masking tape but the result was so bad Sorry I posted it in this thread ...can't remember though to which thread I got the file.
Regards!
Old 29th September 2012, 12:27 PM   #348
de Ocampo's Avatar
Just had the time to finish my DIY -/+15vdc pre-amp power supply...I have tested it to power an op-amp driven dc-protect works fine, only that -rail measures 15.51v and +rail measures 15.18v but I guess I placed different made TIP (transistor) devices. The other was from fairchild and the other one from ST(?).. Anyway it was the device I have in hand.
Thank You! Sir Mile!
Old 29th September 2012, 12:33 PM   #349
DAMANHURI's Avatar
Nice job Sir,
what do you use TIP for this PSU?
Best regards - Damanhuri
Old 29th September 2012, 02:47 PM   #350
IRSound is offline IRSound  Germany
Smile VU TEST
APEX VU Meter Testing with 15KHz Sinusoidal waveform and woofer cooker song.
APEX VU Meter Test with 15KHz & Woofer Cooker - 1 - YouTube
help with single supply for two EQ/preamps lassoharp Power Supplies 3 9th July 2009 03:24 PM
HELP with PHONO and MIC preamps. P Lazkao Tubes / Valves 10 23rd June 2006 01:42 PM
measurement programs, mics and mic preamps. j.burtt Multi-Way 11 15th November 2005 08:08 PM
Power supplies in mic tube preamps JamMan Tubes / Valves 5 2nd November 2004 02:48 PM
mic preamps travis Solid State 7 20th May 2002 05:59 PM
Copyright 1999-2017 diyAudio
