Mic, Line, EQ... Preamps - Page 31 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 25th January 2012, 03:45 AM   #301
DAMANHURI's Avatar
Originally Posted by QQ12e5k1 View Post
Dear Mile...
I was make a new layout of Your tone control with add a XLR con for mic input...I got a plan to make 4 ch mixer with 2 mono input and 1 stereo input but I don't know how to add effect and another block like master and balanced output...
Can You help me to make my simple mixer??
May I know what software you use to design this pcb layout? I saw exactly the same as pcb software which is designed apexaudio.
Can you help me to address a free download
regards
Best regards - Damanhuri
Old 29th January 2012, 10:28 AM   #302
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Originally Posted by apexaudio View Post
Is anybody interesting about 100w guitar amp?
http://www.diyaudio.com/forums/analo...preamps-4.html #32 #35 #37
Here it is,it is assembled but it has 7VDC offset on the output. Ive done something wrong,and now i am going to seek for a mistake. A few pictures:
Old 29th January 2012, 01:31 PM   #303
44250's Avatar
No mistake found-it works just fine! I was doing it last night in my garake and it must be my multimeter gone wrong due to low temperature (-7 / -8C) , or there was metal splinter doing some shortcut on his own. I dont know what was wrong,but it works now. I also found out that i have one NE555,so there will be one more APEX,this time as a protection circuit! Now the only thing i should do is to learn how to play electric guitar! Thanks mr.Mile Slavković APEX , one more time!
Old 1st February 2012, 03:16 AM   #304
How to add this echo circuit with your Apex ML3??
Old 7th February 2012, 09:33 AM   #305
No, there is several mistakes.
Can You show me the mistake??
Old 8th February 2012, 08:11 AM   #306
formula 22's Avatar
Originally Posted by soro View Post
How about this one.
headphone Amps or Preamps.
Hi soro!
Please display the schematic of this hybrid headphone amplifier.
Tanks you!
Old 9th March 2012, 09:35 PM   #307
Default Quitar Amp
Hello, sir Mile. I build your guitar amp, but I do not know what kind are these capacitors: Click the image to open in full size.
In the schematic are given without polarity, but this value seems a tantalum capacitor. I dont know what exactly is ? Please help me, or if it is not important and i dont need to put them. Thanks and Best Regards.
Old 10th March 2012, 07:45 AM   #308
apexaudio's Avatar
This caps are bipolars
Old 14th March 2012, 09:53 AM   #309
Default Problem :(
Hi sir Mile,i cant find exactly 16 volt bipolar caps and i put same with 100volts, which I guess is not a problem except for size. All look normal and final stage work (mean the drivers and MJH11018/17), but my input is line-out, rather than input. In the ''Input'' i dont have any brum and also to pin 3 on TL072. I have signal just on C14 / 33n, and Line-out. The 2 diodes 1n4148 on the input have +/-16 volts. In facts i guess that the preamplifier and adjustments do not work. I dont see any mistakes in the PCB assembly or elements. If you have any idea where can be the problem, I will be happy. Thank you.
Old 14th March 2012, 10:05 AM   #310
Hi Mile, i cant found 16v/33uf, so i put 100v/33uf, i think that thereis no problem except the size. All look normal, the pcb assembly/elements and final stage work( the drivers Mjh11017/18, but my input is line-out, rather than input. I have noice(brum) on C14/33n and ''Line-out'' - input, but not in ''Input'' jack. I check the voltage in 2diodes 1n4148 and there is normal +/- 16v. In facts the preamplifier and the corections doesnt work. If you have any idea or you see some mistakes on the pcb or elements, please help me. Thakns.
help with single supply for two EQ/preamps lassoharp Power Supplies 3 9th July 2009 03:24 PM
HELP with PHONO and MIC preamps. P Lazkao Tubes / Valves 10 23rd June 2006 01:42 PM
measurement programs, mics and mic preamps. j.burtt Multi-Way 11 15th November 2005 08:08 PM
Power supplies in mic tube preamps JamMan Tubes / Valves 5 2nd November 2004 02:48 PM
mic preamps travis Solid State 7 20th May 2002 05:59 PM
Copyright 1999-2017 diyAudio
