Mic, Line, EQ... Preamps - Page 28 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 10th May 2011, 12:48 AM   #271
rifky is offline rifky  Indonesia
rifky's Avatar
Originally Posted by apexaudio View Post
From post #209
i make it, but i feel bass was less. why???
Old 10th May 2011, 11:32 AM   #272
Mr, canou design layout BJT preamp with stereo input and output???
Old 20th May 2011, 07:09 AM   #273
viki_v2 is offline viki_v2  India
viki_v2's Avatar
Originally Posted by QQ12e5k1 View Post
Is this correct now??
hello,
Your attached file does not open , can you repost the file.
Thank you.
Old 31st May 2011, 05:44 PM   #274
Unhappy help me with this ML3
ML3 Schematic
Hi man i know its a bit late to quote this but ml3 that i have made is generating some noise when the vol is open.
espesialy it gets worse when i connect the mic to it.
what coul be the problem.
u know when mics coil is connected the noise is loud and when its not connected the noise is lower but suffering again. what to do man????
Old 6th June 2011, 06:37 PM   #275
hi apex sir .
is this correct method for the tone control?
can i use 20k stereo controls, pls share if u have the pcb layout in pdf format
thanks.
Old 11th June 2011, 07:12 PM   #276
jash2008's Avatar
This simple x-over work in range 20-100Hz, if you need this low pass instead 80-250Hz you can just use pot 2x50k instead 2x10k and sound will be same.
hello apex,
I want to redesign your "APEX sub Mon" into SMD version, will it be possible for you to post its schematic. this x-over really sounds great.
thanks
Old 12th June 2011, 02:13 PM   #277
X-over frequenies are from 80Hz to 250Hz,
what component should be change to x over frequencies are from 20hz or below?
Old 3rd July 2011, 04:32 AM   #278
Mr Mile, can you post your preamp???
Old 6th July 2011, 10:27 AM   #279
shreya is offline shreya  India
Sir
i want this psu for 35-0-35 5A transformer
what changes have to be made on this
Old 19th July 2011, 06:15 AM   #280
radio is offline radio  Macedonia
Banned
Subwoofer X-over with inputs from line or speakers.
Hi Mile!
If you are able to shematic (circuit) the pattern of low-bandwidth filter (Subwoofer X-over).
thanks
help with single supply for two EQ/preamps lassoharp Power Supplies 3 9th July 2009 03:24 PM
HELP with PHONO and MIC preamps. P Lazkao Tubes / Valves 10 23rd June 2006 01:42 PM
measurement programs, mics and mic preamps. j.burtt Multi-Way 11 15th November 2005 08:08 PM
Power supplies in mic tube preamps JamMan Tubes / Valves 5 2nd November 2004 02:48 PM
mic preamps travis Solid State 7 20th May 2002 05:59 PM
Copyright 1999-2017 diyAudio
