PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Mic, Line, EQ... Preamps
Old 22nd April 2011, 06:41 PM   #251
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by RSK View Post
Miles,
I managed to put together the board for your 100W guitar amp.
Well almost completion.
Please advice, 2SK246 can be used insted 2N5638?
Thank you.......Raj
Use J309, J310... 2SK246 different pins, amp can work without 'mute' fet,
Old 23rd April 2011, 07:52 AM   #252
RSK is offline RSK  Malaysia
Miles,
I have already tried using 2SK246(pins rotated). Firing up there is no mute on or off.
I still hear thumb. I have taken off the FET.
Now the amp itself works but signal input at preamp side, I have no gain. With volume at full opened, I hear very low noise.
Therefore connected to amp input with 50K pot at C14, the amp works good.
Very good bass.
Please tell me what to check at the preamp side.
Raj
Old 23rd April 2011, 08:06 PM   #253
apexaudio's Avatar
Miles,
Very good bass.
Raj
Can you post pictures?
Old 24th April 2011, 04:20 AM   #254
QQ12e5k1 is offline QQ12e5k1
Default BJT Pre AMp
Is this correct sir???
Can i use this for AX14 or LM3886??
What the minimum voltage for this pre amp?
Old 24th April 2011, 06:53 AM   #255
apexaudio's Avatar
Connect from base of outputs BC550 to colector of inputs BC560 missing !
You can use this preamp with any amp.
Preamp can work with +/-12V minimum with 18k instead 33k, but use +/-24V.
Old 24th April 2011, 08:48 AM   #256
Miles,
Pic attached.
1)For now I am playing direct input to amp via 50K pot, at C14. Good bass.
Please tell me if any changes needed as above. Is 50K pot or 10K.
What is the bias for each transistors (40mA?)
2) As for the preamp part, hope can be solved.
Raj
Old 25th April 2011, 11:58 AM   #257
vorezky04 is offline vorezky04  Indonesia
Default schematic
Mr. Mile, can i get a schematic/ layour for good tone control subwoofer / x over / good active low pass filter for my H900 and my speaker??
Please.
Thank you for your schematic H900. I feel good for your make power amp.
Old 25th April 2011, 12:03 PM   #258
Mr. mile, Can I get a schematic/ layout for your tone control subwoofer/ x over / good active low pass and high pass filter for my Power amp H900 and my speaker???
PLease.
Thanx you for your schematic H900. It's very very great...
I love apex...
Old 2nd May 2011, 04:08 AM   #259
Is this correct now??
Old 2nd May 2011, 08:43 AM   #260
apexaudio's Avatar
PLease.
I love apex...
Posts #102 and #104,
Mic, Line, EQ... PreampsHide this!Advertise here!
help with single supply for two EQ/preamps lassoharp Power Supplies 3 9th July 2009 03:24 PM
HELP with PHONO and MIC preamps. P Lazkao Tubes / Valves 10 23rd June 2006 01:42 PM
measurement programs, mics and mic preamps. j.burtt Multi-Way 11 15th November 2005 08:08 PM
Power supplies in mic tube preamps JamMan Tubes / Valves 5 2nd November 2004 02:48 PM
mic preamps travis Solid State 7 20th May 2002 05:59 PM
