PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Mic, Line, EQ... Preamps
Old 10th March 2011, 11:33 AM   #231
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Headphone Amplifier with TO92 MOSFETs.
Old 10th March 2011, 11:51 AM   #232
zeraphine is offline zeraphine  Sri Lanka
Originally Posted by apexaudio View Post
IC1 is preamp, IC2 is EQ. Use output from IC1B out if you don't want tone controls.
Thanks Mile, Also can you post the PCB layout for the Preamp you describe on your Class A PSU thread it looks brilliant
A-class Preamp PSU
Old 15th March 2011, 05:51 AM   #233
DAMANHURI is offline DAMANHURI  Indonesia
DAMANHURI's Avatar
Question ASK TONE CONTROLL MR APEX
I've assemble tone with potensio 2x50K controll apex.
I heard the high voice is not good but if in a low voice I feel pretty catchy.
I question whether the components that I use have to be replaced?
help me Mr. APEX.
greeting
The following picture
Best regards - Damanhuri
Old 16th March 2011, 05:18 PM   #234
wattaniya is offline wattaniya
anybody pls give the diagram of wiring the XLR base for amp speaker terminal.
Old 16th March 2011, 08:43 PM   #235
apexaudio's Avatar
help me Mr. APEX.
greeting
Use 1nF instead 3.3nF.
Old 22nd March 2011, 01:59 AM   #236
QQ12e5k1 is online now QQ12e5k1
Default Balanced Input
You can use this circuit with GND lift switch,
Do you have the copper side of this Balanced Input Sir???
In PDF..
Old 2nd April 2011, 05:36 PM   #237
RSK is offline RSK  Malaysia
Default Guitar amp
Miles,
I managed to put together the board for your 100W guitar amp.
Well almost completion.
Please advice, 2SK246 can be used insted 2N5638?
Thank you.......Raj
Old 4th April 2011, 11:16 AM   #238
nix is offline nix  Philippines
ML3 Schematic
hi sir Apex how to add echo volume with your ML3..
regards,
nix
Old 5th April 2011, 03:59 AM   #239
DAMANHURI's Avatar
I do not get the echo effect for vocal sound. always based PT2399.
does anyone else?
Old 5th April 2011, 10:54 AM   #240
does anyone else?
this for microphone with echo volume if he have it possible additional parts or i.c. im waiting for the response of sir apex.
thanks in advance.
regards,
nix
Mic, Line, EQ... PreampsHide this!Advertise here!
help with single supply for two EQ/preamps lassoharp Power Supplies 3 9th July 2009 04:24 PM
HELP with PHONO and MIC preamps. P Lazkao Tubes / Valves 10 23rd June 2006 02:42 PM
measurement programs, mics and mic preamps. j.burtt Multi-Way 11 15th November 2005 09:08 PM
Power supplies in mic tube preamps JamMan Tubes / Valves 5 2nd November 2004 03:48 PM
mic preamps travis Solid State 7 20th May 2002 06:59 PM
