The old PA vs HI FI loudspeaker debate again.... - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 8th May 2010, 12:37 AM   #21
InclinedPlane's Avatar
PA can mean, and often does mean screechy harsh midrange. But I've been totally sold on the old technology for years. My speakers have 3 drivers, two of them are 15"s, all of them have corrugated textile surrounds and none of them ever move more than 2mm. And 2mm is LOUD.
I must confess my favorite music is that made by the Rolls Royce Merlin.
Old 8th May 2010, 01:11 AM   #22
soekris is offline soekris  Denmark
I have always liked the great PA speakers for Hi-Fi, have a theory about them being more linear due to necesserity.... And there is no substitute for displacement * excursion when playing deep bass at high levels.
Have a set consisting of Fane Studio 15Bass, Studio 8M & ST-5022, built 25 years ago and still going strong despite plenty of abuse, including cat claws and being stored unheated. They're great for playing the music I like the best, Dire Straits, at the level I prefer, realistic....
But I will replace them soon with the best PA speakers I can find, NOS JBL 2235H bought on ebay years ago, NOS JBL 2404H from JBL's garage sale years ago and probably PHL 1660 mids, to be purchased soon.... Should then be good for the rest of my life :-)
Soren
Old 8th May 2010, 01:18 AM   #23
Pano is offline Pano  United States
Pano's Avatar
So true, so true. Unfortunate, but true. No matter what the drivers. Comes from trying to get too much volume out of the drivers. Yeah, OK, and bad design too.
But mostly over driving.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 8th May 2010, 01:57 AM   #24
R.I.P.
Help me, now, what JBL PA products used 2235H...?
Old 8th May 2010, 02:02 AM   #25
Ok, the JBL 2235H was more targeting studio monitors.... Maybe I should say PA/Studio speakers as they overlap. On my older days I don't need that high SPL anymore :-)
Soren
Old 8th May 2010, 11:47 AM   #26
indianajo's Avatar
Default High Watt PA
These SP2's will take 300 W RMS each, (45V PP) but I would have to have someone push the start button on the CD player while I listened from the industrial park across the street before I listened to them at that level. I bought the CS800 amp with the speakers, am actually using the DJoffe modified ST120 at about 2v PP, maybe 5v on Joan Jett.(Do you want to *****? BOMP!!!!). If I had to reseat the input connector on the CS800 to get continuity with the power on it would blow my eardrums out. I'm really afraid to hook up the CS800. At these house power levels, I find the mid-range of the SP2 quite smooth, which is weird since it is done with a 2" horn driver and a 1200 Hz crossover. Good highs all over the room. Great easy listening vocals, great soft baroque music, belly shaking sound when I play R&R loud.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 8th May 2010, 01:32 PM   #27
Soren
PA and studio speakers overlap?
I've been to a number of studios and none of them used PA speakers or drivers. The only time I noticed any overlap between the two was in the case of Tannoy but they overlap just as much with domestic speakers.
Court Audio (they provided the famed Pink Floyd PA) used Tannoy drivers, the same ones as were used for studio monitors and home hifi. Other than that I have never noticed any overlap for a long time ie since the early '80s at least.
Old 8th May 2010, 01:59 PM   #28
JamesTRexx's Avatar
Or even at lower levels. I do notice more ease in bass between running the 8 8" open baffles to the bottom or limit them to 70Hz and power on the 12 12" open baffle subwoofers for below 70Hz.
Even the soundstage seems a little wider and more enveloping.
Of course, the louder it gets the better the adrenaline rush as bass still sounds tight and clean. ;-)
Source: FreeBSD & XMMS on VIA Eden, Terratec Aureon 5.1 / Yamaha GT-CD1 Processing: DEQ2496, 2x DCX2496 Amps: 4x EP2000, 2x EP4000
The Gate, best speakers in the world? :-)
Old 8th May 2010, 06:25 PM   #29
R.I.P.
JBL is currently using essentially the same compression drivers in sound reinforcement and high-end consumer audio. They are, however, taming the diaphragms with damping in the consumer product variants....
Old 9th May 2010, 11:54 AM   #30
And JBLs range of studio monitors does not feature any compression drivers at all and hasn't for a long time.
So while there is an overlap between PA/Domestic there is no overlap between PA/Studio.
Which was exactly my point.
PreAmp and Equalizer for Hi-Fi, PA Inductor Solid State 4 8th August 2009 12:57 PM
PA loudspeaker drivers and accessories for sale Bull Swap Meet 21 15th February 2008 03:48 PM
Ciare Hi-fi / High End Loudspeaker Kits willycom Multi-Way 0 6th September 2007 06:38 PM
weird pa loudspeaker driver Bull Multi-Way 1 11th November 2002 09:25 PM
Copyright 1999-2017 diyAudio
