PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
A Club Band PA system
Old 28th April 2010, 08:53 AM   #61
technofreak is offline technofreak  Estonia
technofreak's Avatar
Send a message via MSN to technofreak
Originally Posted by Xoc1 View Post
Crossing over to the coaxial BMS at a low enough frequency to avoid any breakup - beaming on the 12"
Actually you want to cross over at frequency where 12" and horn dispersion angles match, so you don't avoid beaming but use it. I'd say that in this case 15" driver would be preferable, allowing to cross around 800...1000 Hz, but it depends on the horn's actual beamwidth which needs to be measured to get the best result.
Old 4th May 2010, 01:06 AM   #62
Inductor is offline Inductor  Portugal
Inductor's Avatar
Originally Posted by taj View Post
...The coverage area is quite often broken up into different target areas that need to be covered independently. That's the same trouble with using line arrays in clubs. I'll look more closely at horizontal coverage, but I think it would be best to match the horizontal coverage of the waveguides to the 6.5-8" driver coverage -- whatever that is.
..Todd
"That's the same trouble with using line arrays in clubs." Can you elaborate a little on this, I think I understand. If for a to large horizontal coverage problem (is that a problem?!), you'll need more directional (multiple speakers) for alcoves...
Do you think that the interesting RCF H1312 compact type, working with subs, it's a good solution/design-possibility(?) in your case.
A Club Band PA systemHide this!Advertise here!
Band PA Question eddog Solid State 8 15th October 2007 04:53 PM
PA system for band practice DeadSpeaker PA Systems 5 10th August 2007 04:01 AM
Looking for a DIY PA system for my sons Garage Band airframe Instruments and Amps 24 30th June 2006 04:20 AM
PA system got me down.... xstephanx Multi-Way 27 28th April 2006 12:46 AM
