What are the reasonable requirements of a PA system? - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 6th December 2009, 12:00 AM   #11
CLS is offline CLS  Taiwan
Thanks a lot for all your inputs
The venue in question is mainly a lecture hall. And there'll be very many chances of lectures about various tyes of music or movie appreciations. So the system must play music well, especially large scale classical music. (oh well, I know it's not easy... )
That friend (in charge of this) is an administratative personel, not a technical guy. He asked me, "How many drivers, in what sizes, will I need to fullfill this room?" I said to him "Well, that doesn't make good sense. They can sell you anything in those sizes and numbers, but not the sound you want." He listens to quite a lot of classical music (through his LP turntable, Lowthers and ancient RCA amp... ), but knows almost nothing in PA system.
I don't know much, either But I know such system working in such space is very different from a hifi system in a living room. I said to him, " You must give up those 'hi-end' concepts of a home system, it's already really difficult to get a uniform coverage, relative flat and clean response in a required SPL in a large space, let alone those hi-fi delicacies like 'micro-dynamics', 'extensions', 'details'... etc."
And sadly, I haven't experienced any 'good' PA system here in Taiwan except for an I-Max theater in an national museum. Pro-sound market is too small here to support a healthy industry. Some equipment of big brands can be bought, but I always feel the system integration and setting are not as good (as those brand names). And no, we don't have any dealer of Mayer Sound here, unforturnatey.
I'll be studying the links provided above, thanks a lot, again
Old 6th December 2009, 12:15 AM   #12
Winly Group
They are located in Taipei Taiwan
Cheers
Old 6th December 2009, 11:30 PM   #13
Thanks for reminder
Actually, I've heard of this. Maybe it's the biggest in this business in Taiwan. They've been in countless major events. (I didn't know they got Meyer Sound.)
Old 7th December 2009, 07:11 PM   #14
rcw is offline rcw  Australia
The requirements you have probably can be met, but I suspect the bucks will be considerable.
Something more like a final mix down theater, used in the film industry to mix and audition soundtracks, with a Genelec main monitor set up, would be ideal.
The question is does the budget run to it.
rcw
Old 8th December 2009, 12:03 AM   #15
Hi rcw,
Thanks for comments. I didn't know Genelec makes speakers for auditorium (or theater, concert hall... etc). Does (large) studio monitors handle such application well?
I think it's perfectly feasible to see it as a theater. Though it's mainly a lecture hall with 600 seats, all kinds of music and movies will be played here, too. Highest achievable sound quality is the main goal.
And, do you mean the conditions I listed:
"near the center region, measured frequency response should be:
40 Hz ~ 12kHz, +/-3dB @ 108dB average SPL
and 32 Hz/16kHz are better than - 6dB;
for outer regions: 50 Hz ~ 10kHz, +/-4.5 dB @ 105dB average SPL
and 40 Hz/12kHz are better than - 10dB
And decay time (T60) should be under 1 sec. "
are doable but expensive?
What part(s) cost more? Bandwidth, flatness, or uniform coverage?
Are these conditions proper, or desirable? Should we ask for more, or compromise somewhere?
Let's assume the budget is, say, US$ 150k (or equivalent). And what will be a proper goal, and it's technically achievable ?
Thanks again,
CLS
Old 8th December 2009, 01:24 AM   #16
What you are looking at is a picture theater type set up that is intended only for playback of prerecorded stuff, and not for live performance, (apart from a single mic. for lecturer).
No need for recording extensive mixing or fold-back etc.
I imagine that you can do this for the sort money you mention since these are standard types of set ups much installed in multiplex cinemas.
This can become complicated if the venue is an older building or has an unusual shape.
The only caveat is that a lot of them produce a lot of sound but fewer produce a lot of good sound.
The krix company has installations all over South East Asia and Japan, as I imagine Meyer sound does, and it wouldn't hurt to contact them and ask.
rcw.
Old 8th December 2009, 02:58 AM   #17
After a little invetigation, I realized that Krix has deployed their products in some major cinemas here. I've been to some of them, but TBH I don't remember how they sound. The opinions on web varied a lot on different sites. So I'd guess the final setting of the system would dominate the results.
High end system for reasonable cost Dr_EM Multi-Way 6 16th July 2007 01:23 PM
Is it reasonable to have a sub go from 20 to 120hz? bluegti Subwoofers 5 18th September 2006 01:13 AM
Still can't get reasonable numbers mashaffer Multi-Way 13 10th July 2006 04:55 PM
reasonable powered simple amp beamnet Tubes / Valves 6 24th June 2004 09:36 AM
Copyright 1999-2017 diyAudio
