PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
The cheapest PA system
Old 1st December 2008, 07:45 PM   #1
andrew_87 is offline andrew_87  Italy
Lightbulb The cheapest PA system
Hi guys!
i'm here to show you my new project: a PA system with a super performance/cost quotient.
target:
- f. response: 45hz(f3) - 16000hz circa
- hi max spl (near 140dB)
- stack use (0.5phi)
- low cost
after some ideas i have realised that to contain cost i have to create a 2way system:
- low frequency: 45hz to 500hz (if it is possible highest, like 800hz but i will test it)
- hi frequency: 500hz (800hz)to the highest possible frequency
- eventually piezo tweeters
to have a very high SPL i decide to use horns: frontloaded horn is probably impossible (due to freq. range), so i will project a rearloaded horn, i don't really like rearhorns but in this case i will use!
the driver that, in my opinion, has the best performance/cost quotient is the Skytronic 902.442:
http://export.skytronic.com/product/....php?s=902.442
a cheap 12" whit big voice coil (100mm) and good t&s for a horn.
Here is the project using HornResp:
and here is the project using AJhorn:
GOOD! (in my opinion)
i would create 4 scoopbin, so i can create a stack and work in 0.5phi... probably i can get 140dB whit only 1.2KW from this bass system...
for the high frequency i probably use this compression driver (but i don't know if they can go to 500hz):
http://www.usblaster.com/Products/DJ...ers//USB%20387
or this:
http://www.usblaster.com/Products/DJ...vers/USB%20384
(probably the first)
in my opinion i need 4 compression driver with few watts: so i can improve the durability of the system.
what do you think about this crazy project?
Old 2nd December 2008, 12:24 PM   #2
no opinions?
Old 2nd December 2008, 06:58 PM   #3
HK26147 is offline HK26147  United States
My opinion - though you may not not want to hear it is:
A 2 way PA with a clean output of 140db is a lofty goal. I won't say it's impossible, but you want it cheap as well?
I am unfamiliar with those drivers you mentioned, nor have I seen any feedback on them... Based upon the pdf specs:
The 12" driver has only a 4mm excursion - Excursion limited and Insufficient to generate that sort of SPL before mecahnical damage or thermal failure, I'm guessing.
It's been my experience that a PA made from cheapest parts can not be made to sound good, and will not be very durable and robust.
There is a huge sonic difference in a PA made with cheap parts and one made with name brand drivers.
You pay a lot of money for a driver like a 2206 or a 2226, but after over 8 years and thousands of watts they still sound better than new OEM drivers.
I repair drivers and so I would rather repair a used/damaged ( cone tear etc ) JBL then buy a new OEM despite price.
Old 2nd December 2008, 07:21 PM   #4
probably 140dB is too high for my application... and this is impossible for this kind of product...
I will test the woofer and the driver, after this i will decide...
thank you for your opinion!
Old 2nd December 2008, 07:52 PM   #5
anothor thing, what do you think about my rearloaded horn project?
thanks
Old 2nd December 2008, 07:59 PM   #6
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
By the time you reach 140dB your nose starts to bleed.
I agree with HK, 140 is a bit lofty. I run 6 15" horn loaded Selenium PA woofers plus 2 horn mids and 2 horn tweeters and expect a clean 125 dB with 1.5K of power.
Tell us what these are for, maybe we can help.
planet10 needs your help:
Let's help Ruth and Dave
Old 2nd December 2008, 08:03 PM   #7
i have calculated a theorical spl at 1 meter in a 0.5phi emission...
so real 115-120dB are enoght!
i would create this system for a carnival wagon...
Old 2nd December 2008, 08:37 PM   #8
Forum member Davygrvy built 6 horns each with an Eminence HL10 ( Total Driver cost $780 ). These horns formed a fairly small stack.
And when given enough power produced painful SPL.
I used to set up a parade float sound system myself, and I'm guessing his stack would fit your carnival wagon system.
But not as a 2 way.
Old 2nd December 2008, 08:45 PM   #9
my metod to have an approx of the max thoerical output,
i use it to note the difference between different thorical project...
isn't correct but for approx the difference between project is good...
Old 2nd December 2008, 08:50 PM   #10
another simulation...
140dB was refered to these simulations...
The cheapest PA systemHide this!Advertise here!
Cheapest USB DAC kit? Spasticteapot Digital Source 0 16th November 2006 05:56 AM
Cheapest kit or project? yamski Tubes / Valves 14 26th May 2006 01:59 AM
Cheapest Solution bjackson Solid State 3 2nd August 2005 04:18 AM
Cheapest 12" Sub seangoesbonk Multi-Way 15 11th December 2004 09:15 PM
cheapest good sound system possible? r3n0 Car Audio 6 14th October 2004 06:28 PM
