PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Help reqd - power bass for PA use
Old 20th September 2008, 06:02 AM   #11
ostripper is offline ostripper  United States
ostripper's Avatar
By Andrew t:The first 5 opamps and the circuitry around them might give you a clue to the lost bass.
I agree .. try bypassing all the opamps ,drive the amp directly
("PA" direct to first stage) WOW ,is this amp huge or what!!
What are the rails at 120-0-120V ???
Also ...C's with ?? marks at input + NFB loop ,what are they???
Old 20th September 2008, 07:03 AM   #12
mhtplsh is offline mhtplsh  India
I agree .. try bypassing all the opamps ,drive the amp directly ("PA" direct to first stage) WOW ,is this amp huge or what!! What are the rails at 120-0-120V ??? Also ...C's with ?? marks at input + NFB loop ,what are they???
This means no need to keep opamps in the path. Just bypass it.
The amplifier is huge.
I hvn't checked the supply rate.
I will check the value of C in the feedback path.
Old 20th September 2008, 10:35 AM   #13
jaycee is offline jaycee  United Kingdom
My money would be that the amp is not the problem - its the speakers. This is why speaker/amp combos for bass guitars have huge speakers usually designed for this sort of work.
Old 20th September 2008, 12:50 PM   #14
I tried this also.
The same speakers under same conditions give more powerful bass with another amplifier.
Old 20th September 2008, 12:55 PM   #15
audiomachines is offline audiomachines  Philippines
Send a message via Yahoo to audiomachines
i agree the amp is not the problem, its the speaker system. why not build a kick bin for that tight and punchy sound. Try this site www.speakerplans.com. Hope this helps.
best regards,
audiomachines
Old 24th September 2008, 09:12 AM   #16
ostripper :
I located the components. The c? is 100/25v BP. But the resistor in series with it is 1.2k.
This means that the gain is just 20.
I think it will be better to increase the gain to 33.
So i will replace the 24k resistor feedback resistor with 39k.
Plus should i replace 100/25V bipolar with 220/25vBP or more.
Old 24th September 2008, 11:32 AM   #17
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
If you are not needing to have the input level control at max then you don't need more gain. Changing gain will affect the stability of the amp.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 24th September 2008, 12:48 PM   #18
R.I.P.
Increasing amplifier gain improves stability, reducing gain is the no-no.
/sreten.
Old 24th September 2008, 04:11 PM   #19
sreten:
So what i am going to do is right. Increasing the gain in limit which is not extended upto oscillation.
Old 16th September 2010, 03:38 AM   #20
C3PO is offline C3PO  Philippines
Default t-amp proline 3000
Originally Posted by mhtplsh View Post
The amplifier is with heavy duty transformer & power supply. It is used for pa. But there is no powerful bass as required. What modifications might be required to get kick bass for PA use.
hi, is this your amp?
Help reqd - power bass for PA useHide this!Advertise here!
JBL eon15 g2 schematics reqd jayam000 Solid State 2 14th August 2012 02:44 AM
bass preamp and power amp superseadragon Solid State 1 13th July 2007 07:23 PM
Advice reqd on TORIVIN PRODUCTS (INDIA) rikhav Multi-Way 3 12th November 2006 06:26 PM
Bass power nag1_uk Everything Else 10 28th April 2005 02:58 PM
Tda 7377 Datasheet Reqd palesha Chip Amps 0 15th December 2003 05:56 PM
Copyright ©1999-2017 diyAudio
