Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 27th July 2007, 03:18 PM   #21
Well I don't have any picture of it but I might arrange one if time permits.
The tops have handles and we just hanged these from the ceiling (or whatever) by running some packing straps down through one of these handles and around the bottom and up again on the other side. I.e the handles were just used for keeping the strap in place and not to carry the weight. We did not use any real flying harness. Doing this you have to watch out to comply with local safety rules. Since we mostly use the system for private parties this is less of a problem if common sense is used.
Charles
Old 27th July 2007, 04:20 PM   #22
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
Send a message via MSN to AKN
crissty,
Have you tried to plug port on midtops when running together with the scoops?
The plug could be some kind of wood plug, easily removed when running the tops alone.
/ Anders
Old 30th July 2007, 06:34 AM   #23
That's how I use to fly them (this one is smaller than yours though). Moving the tops a bit out od the scoops nearfield might help by great lengts. Youll hjust have to try to find out.
Charles
Old 30th July 2007, 08:55 AM   #24
pinkmouse's Avatar
Crissty, please do a simple experiment for me. Sit the mid/high boxes on the scoops as normal, but don't connect them to anything. Fire up the bins to working volume, and see if the cones on the mid drivers move. I suspect they won't.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 30th July 2007, 09:32 AM   #25
Foxx510 is offline Foxx510  Australia
From what I can gather, he has done that and they do indeed move. I would try some foam plugs in the ports of the top boxes.
Old 30th July 2007, 09:38 AM   #26
Or maybe with the input connectors shorted !
Charles
Old 31st July 2007, 08:07 AM   #27
crissty is offline crissty  Greenland
It does move.
IMO Plugging the ports might not solve the problem, cause the box volume is approx 70liters, and so would not restrict the movement of the cones.
I think the best solution would be to use Mids as horn loaded with small back chamber.
Old 31st July 2007, 11:26 AM   #28
pinkmouse's Avatar
Very strange, I have never experienced that kind of behaviour, and I've played with a lot of PA boxes.
I would try the bungs anyway before you rebuild the boxes.
Al
Old 31st July 2007, 02:54 PM   #29
bungs
Old 31st July 2007, 02:57 PM   #30
pinkmouse's Avatar
Sorry, plugs for the ports.
Bung
Al
I designed my bass and need a midtop... robotnation Multi-Way 4 12th August 2009 11:47 PM
A.S.S scoop bass bin plans WANTED Bull Subwoofers 4 19th March 2009 04:51 PM
Empty 18 inch scoop bass bins WANTED!!! Bull Swap Meet 4 2nd June 2005 02:05 AM
Help me with SCOOP bracing . darkm4n Multi-Way 2 20th January 2004 09:45 PM
Scoop comparation darkm4n Multi-Way 2 14th January 2004 07:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 18.18%)
Copyright ©1999-2013 diyAudio
